Question about U Haul U-Fortify Heavy Duty Disc Padlock 2-3/4"
I lost my key to my U-Fortify Heavy Duty Disc Padlock 2-3/4" can i use a bolt cutter to break it?
  • 1,869 Answers
I already answered this post
Posted on Nov 18, 2013
Why does the head stop moving?
with trimmers , there is a shaft or as in a bent shaft a cable that has square drives and ends
these can become oval or break off if continual heavy loads are applied to the cutter head
next there is a centrifugal clutch at the top of the shaft and if continually used in heavy work that clutch will wear out and not grip sufficiently to drive the shaft
most cutter heads do not suffer problems other than to get loose and work down the tube thereby allowing the square drives to part
Jun 24, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
I lost the key to my U-Fortify Heavy Duty Disc Padlock 2-3/4", can i use a bolt cutter to break it?
use an AC powered mototool and the little circular carbide blades made for it. stack two blades on the shaft for strength and,
you can cut right through the hasp or. case with it
Nov 18, 2013 | U Haul U-Fortify Heavy Duty Disc Padlock...
Plastic Stuck on Mounting Bolt
Easiest way I can think of would be just to use a pair of side cutters, or wire cutters, and break it off.
Nov 07, 2013 | Dodge Cars & Trucks
Cut padlock and chain off without ruling them
Bolt cutters will work unless the chain is hardened steel. If it is hardened steel use a hand held grinder.
Nov 04, 2013 | Garden
I just bought a Kobalt 20" tile cutter- it came with no user's manual. where can I download one?
Hello, go to Lowe's hardware store. They handle Kobalt tools. I wish you luck. GB...stewbison
Sep 22, 2011 | Heavy Duty Kobalt Tile Cutter In Box 20 "...
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
Problems with a replacement radiator.
check that shroud difference is not a fan to core 'clearance' issue.
1. drill new holes in shroud ?
2.fabricate a bracket out of strap steel to bolt them together ? 3. go back to advanced auto for heavy duty ready shroud ?
Oct 10, 2009 | 1991 Ford F150
Cannot unlock it
Your gonna need some heavy duty bolt cutters ... Or get with the guessing numbers game.
Apr 20, 2009 | Computers & Internet
Braun 360 shaver. How to replace the cutter.
You simply have to pull it hard enough to get it out. I had hesitated to do this, fearing it would break.
Jan 04, 2009 | Braun Replacement Foil/Cutter for Select ...
Maintain light
it could be as simple as oiling the cutter rollers "Once a week squirt oil on sheet of paper that will be shredded. Do 3 or 4 sheets." as found on fix-ya or it could be a paper jam detector.
Jun 04, 2007 | Universal Medium-Duty 38012 Shredder
U Haul U-Fortify Heavy Duty Disc Padlock 2-3/4" Logo
134 people viewed this question
Top U Haul Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an U Haul Lock and Locksmithing Expert? Answer questions, earn points and help others
