Citifon already unlock but the touch pad has freez,would you like telling me what to do
Would you please help in checking all the products sold by telecom png
SOURCE: touch pad freezes
I just tapped & tapped on the pad until it worked, when I discovered what released it it was the arrow (one to the right & one to the left ) on the very upper right hand corner of the touch pad. Now when it turns blue & freezes touching that section unlocks it. I have no idea why this happens.
Posted on Mar 25, 2008
  • 3940 Answers
SOURCE: Touch Pad
In the touchpad settings (Control Panel, Mouse) see if tap to click is enabled, if so uncheck and see if there is any difference. Also try booting in the safe mode, and see if that changes anything (F8 during boot to access safe mode) If no difference, then you'll likely need a new palmrest to fix the touchpad. If the touchpad works normally in the safe mode, try a new touchpad driver from support.dell.com
Posted on May 10, 2008
  • 116 Answers
SOURCE: touch pad freezing
there is a loose conection
Posted on Jan 09, 2009
1234s282
  • 144 Answers
SOURCE: Touch pad not working
Go to device manager
Right click the touchpad device
Uninstall driver
Reboot system
go here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-66690-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795289
Reinstall touchpad driver
see if that helps
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Posted on Jul 01, 2009
phoenix chi
  • 389 Answers
SOURCE: touch pad is not working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is there any instance that the phone was dropped or exposed to liquid? If some keys on the phone is no longer working it really needs service.
Posted on Jul 18, 2009
It's a driver related issue or the touchpad is locked. Unlock it.
Each computer has it's own way on how to unlock the touchpad. Please provide me with the model of your computer so that I can provide you with the correct steps.
You can also scan your computer with RadarSync so that you will know if the drivers are out-of-date especially the touchpad driver. Your touchpad stops working if the driver is out-of-date so you might want to check RadarSync.
David
Jun 16, 2013 | BenQ Computers & Internet
My samsung ce0168 is freeze i put in the wrong code too much time and it freeze please help. thank you.But when i touch any code a found in the web dosn't unlock
If your phone displays the 'phone freeze deactivation fail' then your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone.
You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
Aug 18, 2011 | Cell Phones
Amana side by side water in the door wpn't shut off. If I open the freezer door it will shut off. I have tried to unplug it and replug but that doesn't help. Model # ARS2667BS.
it sounds like the touch pad button is stuck in so it's like someone is always pushing on it,when the door opens the contact in the door switch stops the power to the board,when you close the door the power goes back to the board.you can check this by disconnecting the ribbon that comes off the touch pad and plugs into the board,unplug the fridge then you can unplug the ribbon,when you plug the fridge back in if the water stops coming out you know the touch pad is bad,if the water still comes out then the board that the touch pad plugs into is bad.you can call your parts store and see if the touch pad comes with the board,i've found this problem on other machines and they sold everything together,but if the parts are sepatate do what i said,unplug the ribbon if the water stops the touch pad is bad,if it doesn't then it's the board that's bad.you can shut off the water at the valve that connects to the fridge if you haven't done that already and then do the tests .good luck.
Apr 25, 2011 | Refrigerators
How do you unlock a cell phone?
Follow instruction on the screen. Look for the pad that says unlock. Once you press it, it directs you to another pad to finally unlock your cellphone. In nokia product, press enter pad then press right away (*) asterisk. In Motorolla, press (--) above the center main pad then asterisk and then it unlocks your phone.
Thanks.
Dec 12, 2009 | LG enV Touch VX11000 Cell Phone
Uninstall driver
Reboot system
see if that helps
Kind Regards
1234s282
Jul 01, 2009 | HP Pavilion dv4000 Notebook
Touch pad freezing
Jan 09, 2009 | HP Computers & Internet
Unlock a microwave
hello jeansween ,
can you double check that number please , R-4446 ?
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=r&s_func_disp_id=19&x=24&y=6
heres a list of sharp microwave owner manuals .
to cancel child lock you touch timer/clock pad, the number 1 and stop/clear pad
hope thats understandable .
Jan 02, 2009 | Sharp R-308J Microwave Oven
Kenmore micowave
IF IT IS THE KEYPAD THAT IS LOCKED, ONE OF THE TOUCH PADS SHOULD BE HELD FOR 5 SECONDS TO UNLOCK THE
TOUCH CONTROL.YOUR INSRTUCTION MANUAL WILL TELL
YOU WHICH PAD TO HOLD. IF NOT AVAILABLE, TRY EACH PAD, ONE AT A TIME. HOLD EACH PAD FOR 5 SECONDS.
IF NO RESPONSE, TRY THE NEXT ONE. WHEN YOU FIND THE ONE THAT UNLOCKS THE CONTROL, WRITE IT DOWN
FOR FUTURE REFERENCE. THAT PAD WILL ALSO LOCK THE CONTROL WHEN HELD FOR 5 SECONDS.
Mar 28, 2008 | Microwave Ovens
Touch pad freezes
reinstall your os, install best antivirus of today. it is the problem of your os and virus if its continues then problem with your hardware (cpu fan).
Mar 18, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
