Question about Empire Scientific CA1270 : CA1270 Ni-Cd for Maxon SP2850 Equivalent Battery : WKTKMX018
How to program the Maxon SP2850 - Empire Scientific CA1270 : CA1270 Ni-Cd for Maxon SP2850 Equivalent Battery : WKTKMX018
CAN THE MAXON BE RE-PROGRAMMED TO COMPLY WITH THE NEW FCC REGULATION OF NARROWBANDING?
It depends on the model and when it was produced. You might try googling the model number of the radio. Or you could call Maxon at 800-821-7848.
Best regards.
Sep 12, 2012 | Maxon Radio Communications
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Nov 15, 2009 | Maxon Radio SL55, SP130, SP140, SP150...
Beeping Error Code on Maxon SP2805SC
That is a programming code. They were linked to a repeater and they are telling you they can't find it. Get them re-programmed.
Jun 22, 2009 | Radio Communications
I boought two maxon radioa and need an operators manual
Hi well, I would advise you to try the internet place the model etc on this media, and also try ebay,
worth a try some one may be able to help,
Cheers,
John
Apr 07, 2009 | Maxon GMRS50 (16 Channels) 2-Way Radio
Maxon MCB-30 CB Raido
what do you mean program it? swr?
Mar 18, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Maxon SL25
if the band assigned to the radio doesn't cover the frequencies you want then it will not happen. you need to get the software and the right programming lead. make sure the mic socket is good and clean
Nov 19, 2008 | Honeywell Maxon SL25 Two-Way Radio Battery...
Maxon sl70
You may want to search this site for a manual.
http://mods.dk/
Jun 20, 2008 | Maxon GMRS50 (16 Channels) 2-Way Radio
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon sl100
Hello baba_zam,
The Maxon SL100 can be programmed but doing so requires a programming kit including software and a specialized cable. Unless you are going to be reprogramming a lot of units regularly, you are going to be best served by taking the unit into your local Maxon dealer and paying them to reprogram it for you.
Best Regards,
Ken
"Go Ahead. Use Us."
May 31, 2008 | Radio Communications
Empire Scientific CA1270 : CA1270 Ni-Cd for Maxon SP2850 Equivalent Battery : WKTKMX018 Logo
55 people viewed this question
Top Empire Scientific Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Empire Scientific Radio Communication Expert? Answer questions, earn points and help others
