Question about Watches
How do i reset my easson es 14 digital readout
ONLY A B S ILLUMANATE
Instructions for Boss 1512588
The bottom dial gives you a readout in 24 hour time used by the military. 2 oclock in the afternoon would appear as 1400 or 14 on the third dial.
Dec 25, 2012 | Watches
How can I "unfreeze" the digital readout on my timex WR 50m watch?
You may need to remove the battery and then reinstall the battery. Then there is a small spot on the movement that you touch while simultaneously touching the top of the battery. This will reset your watch. Somewhat like rebooting your computer.
Oct 19, 2011 | Watches
How do u set the time
complicated, very complicated. Go to Citizen website and they have directions for all their watches. Basically, you set the digital and the hands then correct to what the digital readouts say.
Mar 23, 2011 | Citizen Blue Angels Skyhawk Watch
Utc Dial does not match Digital utc readout and I can't for the life of me figure out how to sync them
I finally figured this out... You must zero all the hands by setting the mode to CHR and pulling the stem to the second stop. Go through the process of setting the hour and second hand to zero. The secret is that zeroing the MINUTE hand also controls the UTC display zeroing. You will have to crank it until the UTC display reads 0:00 (24:00). Then go back and set the time and so on as usual.
May 11, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Eco-Drive Blue Angel Watch C650. I can't get the analog to match the digital. i have reset everything to the O positon. Reset time, calendar.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all citizen watch manuals. Rate me, please.
Mar 02, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Change time for digital readout
Got as a gift with no instructions to set time
Nov 20, 2009 | Casio Sports Analog Digital Tide Graph...
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
DECADE WATCH HAS NO SETTINGS MANUAL
If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8 "o'clock" positions respectively; and one pull and turn stem (at 3 o'clock position) -
For the purpose of setting the watch and functions mentally label the push buttons as follows:
10 o'clock position "A"
8 o'clock position "B"
2 o'clock position "C"
4 o'clock position "D"
NORMAL TIME SETTING
1) In normal time readout press B (3x) to get to normal time setting mode: "SEC" will start flashing, press C for synchronization
2) Press D once: "MIN" will be flashing, press C to advance
3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
4) Press D once: "DATE" should be flashing, press C to advance
5) Press D once: "MONTH" should be flashing, press C to advance
6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
7) Press B once: Setting is completed, return to normal time readout
ALARM TIMES SETTING
1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance
2) Press D once: Alarm time "MIN" should be flashing, press C to advance
3) Press B once: Setting is completed, return to normal time readout
ALARM FUNCTION
1) In normal time readout press C and D simultaneously: Alarm signal should appear
2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour)
CHIME
1) In normal time readout press D and B simultaneously: Chime signal should appear
2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
CHRONOGRAPH (STOP WATCH FUNCTION)
1) In normal time readout press B once to get into "CHRONO" mode: press C for to start counting event -
While in Chrono mode there are two options
a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00
b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00
2) press B to return to normal time mode
Mar 27, 2009 | JCPenney Watches
Digital readout on the titanium touch reads bAE.
battery almost empty? sounds about right... I just got this now
Feb 23, 2009 | Tissot T-Touch T33759851
Casio Wave Ceptor Watch Model WV 109 HA
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
Apr 22, 2008 | Watches
Watches Logo
55 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
