G drive blinking light
Blinks light and won't appear on desktop
  • 146 Answers
SOURCE: My book will not appear
What OS are you running? If it is a Mac, does the Disk Utility see it? If it is detected but it doesn't mount it needs to be initialised partitioned and formatted. You may need to partition it in smaller chunks if the computer or OS is older as they were not made with 500 GB and 1 TB drives in mind.
If it is Windows, try running the utility that came with it and see if it is recognised, or try the Disk Management tool in the Administrative Tools section of the control panel. If it is not seen by those utilities at all, it is possible you have either a bad cable, the drive is bad or the driver is not loaded for whatever reason.
Check those things and see if you get anywhere. Feel free to contact me again if you need any more help.
Cheers.
Posted on Dec 27, 2008
  • 28 Answers
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Posted on Sep 14, 2009
  • 206 Answers
SOURCE: Icon won't appear on desktop.
It is possible that your USB flash drive is dead.
The other solution is to try it on some other USB port of your PC (if you used front panel USB ports now try it on the back panel).
If it also wont work, try to connect it to some other PC
If it works with an other PC, your USB ports are dead
You can try going to device manager, and to unintall USBs and reinstalling them
Posted on Nov 14, 2009
firesnake09
  • 2923 Answers
SOURCE: drive not working/ not showing on desktop/ green
Do you hear a clicking sound while the HD (hard drive) is ON? If not, here's what you need to do:
1. Try to connect the HD into different USB ports of your computer. Or might as well, try different computer.
2. If you're using USB cable to connect the HD to the computer, try different cable. If it has a FireWire connection, then try FireWire.
3. If same problem occur, check the Disk Management of your computer while the HD is connected. To check the Disk Management, here's how:
- Right click "My Computer" (for XP) or right-click the "Computer" icon (for Vista or Win 7).
- Go to"Manage", then select "Disk Management".
- List down all the drive letters that you will see. Include the "Unallocated" disk space on the list(if there is), then unplug the HD from the computer.
* If there's a drive letter that disappears, then it's your HD. You may reconnect the HD to the computer > right-click on the HD's drive letter > change drive letter. Try to set the drive letter of the HD in drive X: or V:.
* If the drive letters remained the same, though you disconnect your HD, then, it means that the HD is no longer detected by the computer.
* If the HD appears to be "unallocated", then you need to reformat it.
*** However, if you're hearing a clicking sound, I'm sorry to inform you that the HD is no longer working. That clicking sound is also called the "click of death".
Thank you and good luck!
Posted on Jul 04, 2010
bronk50
  • 27725 Answers
SOURCE: external hard drive keeps on
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Aug 19, 2011
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Fast blinking light on drive a slow blinking light on b on dell dim 4700
Yes, the HDD LED will Blink when active. "slow blinking light on b", what is b?
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
Computer won't come on. light is blinking in back of hard drive.
Try unplugging from wall socket then press on button (this clears out extra electricity in PC). Plug back in then try to turn on again. If PC is older, try blowing out the dust inside tower especially around the CPU fan.
Aug 04, 2012 | Compaq Computers & Internet
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
My computer won't start up and is blinking yellow. How do I fix it?
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
What does the blue blinking light at the very bottom, under the blue power button indicates?
According to the Dell 531 owners manual:
"Drive activity light-
blue light - A blinking blue light indicates the computer is reading data from or writing data to the SATA hard drive, CD, DVD or HDD."
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Safe to ignore. It will blink even when the computer appears to be idle.
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
My Dell Studio 540 blinking hard drive light
the hard drive light blinks whenever the Hard drive is accessed, and sine this is where everything is stored, that happens a lot. the only way to completely disable it is to unplug it from the motherboard.
Jan 15, 2010 | Computers & Internet
Not booting, blinking light
4 blinks, 1 second apart is a power supply overload. Have the power supply replaced if you haven't added any additional hardware lately. But also make sure your hard drive isn't bad and pulling an overload of power. it's rare, but I have seem that happen on some western digital hard drives.
Jun 13, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
