Panasonic cinemavision 1080i power light blinks red twice, will not turn on
Can hear clicking sound if i unplug, plug in, try again. worked earlier today. Will repeat blinking twice.
  • Cody Nocton
    Cody Nocton Nov 18, 2013
    I've browsed the site for about an hour and have found no solution for blinking twice. its not blinking 5 times or 3 times, its only twice just to clarify
  • 19,396 Answers
The clicking sound is a safety device that prevents that TV from starting because a fault has been detected.
The fault is also indicated by the two blinks. Two blinks point at a problem with one of the low voltage lines (it should be 15V) from the power supply. The PSU is the part to be tested and eventually replaced. Before calling the technician try to unplug the power cord and leave the TV to rest for about one hour before restarting.
Posted on Nov 18, 2013
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Posted on Mar 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: My Panasonic Cinemavision 1080i PT53WX42F
IC4511 isnt comunicating. Replace the DG board
Posted on Oct 23, 2010
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
My Panasonic Cinemavision HDTV keeps shutting off. I can turn on for about 5 seconds then it goes off. No blinking red lights, just power off. I can unplug the power supply and plug back in and get the...
It is the problem of your transformer. It might have got damaged in lightning or voltage fluctuation. Replace that small and cheap equipment to find your tv work again. When having a new one, go for the best thing available in market or else the new one too will go out soon.
Apr 18, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Panasonic TH-42PX80U won't turn on.
You are missing 15volts. If this is a new TV, it could be as simple as a plug not fully seated on the power supply. Regardless, the repair should be covered by warranty and Panasonic is one of the best when it comes to taking care of the customer. Ifd nI can be of further assistance, let me know
Dec 21, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Mar 25, 2008 | Televison & Video
My Tv won't turn on...
The two blink code "could" mean a problem in the power supply. I believe a 3 blink code means the 3.3 Volt Supply Is bad on the power Board. I would price the new 42" LCD TV's vs repair costs before proceeding.
Jan 25, 2007 | Panasonic TH-42PA25U 42 in. HDTV Plasma...
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
Electro Med Services...
