Question about IBM ThinkPad T30 2366 Notebook
T30 boot problem
T30 with XP Pro. I was using the computer and it froze. Powered down and rebooted with no problem. Ran a registry check and found 41 errors. Most related to a bunch of shortcuts I cleared off my desktop. On reboot after registry repair, I got an error immediately after entering password saying the system had to shut down and if this was the first time I got this error to reboot. On second boot attempt, it locked up prior to the password screen. On third attempt, I was able to boot in safe mode and powered down. After that, I can not even get the IBM screen to come up. I removed HD and put it in a external drive kit and am able to read it, but have not run any other diagnostics on it. Tried a new HD with no luck. On occassion I get 3 or 4 sets of 4 beeps
  • 1 more comment
  • dfulper Oct 10, 2007
    Update. I was able to boot in safe mode and did a registry restore. When I tried to reboot a second time, I recevied the same error, i.e. "Windows had to shut down to prevent damage to the computer..............Check for viruses, do check disk, etc." Tried to reboot a third time in safe mode, but can not get by this warning message.
    Followed the advice given above regarding memory slots. Computer originally configured with 1 gig matched memory split between both slots. Slot-1 = slot closest to front. Slot-2 = slot in back.
    Computer sometimes will attempt to boot with both sticks in. Computer consistently will boot to error screen with original stick in slot-2. Will not boot if I take stick from slot-1 and put in slot-2. Gives a beep code of 1-3-3-3 with slot-2 stick in slot-1.
    Starting to look like that at least part of this is memory related. Not sure how to confirm if it is sticks or slots, and whether there is additional problems associated with Registry and/or HD. Does the warning message that I get imply that damage could have been done that would have affected one of these?
  • dfulper Oct 17, 2007
    I tried pressure on the memory, and was able to post, but then I would get an error saying that windows had to close down to prevent damage to the computer.  I could not get it to get past this screen, and I could not get it to even post with both sticks.  I would only post with one specific stick in slot #1.  I borrowed another T30 and put my hard drive in it and it fully booted with no problems.  I moved the memory from this computer (512K) to the bad computer and it also booted.  I thought great, I just have some bad memory.  I took the potentially bad memory (1 Meg) and put it in the good computer, and it booted with no problem.  So now I am really confused.
  • dfulper Oct 18, 2007
    I realized I needed to do one more test, i.e. move the 1 gig memory back to the bad computer.  Sure enough it will not post with those sticks in.  So it sounds like the sockets are bad, but that this is only critical with 1 gig sticks.  So now my question is is it safe to run the "bad" computer with 512 meg sticks or am I flirting with disaster?
  • 181 Answers
Sorry, but probably your T30 (my favorite Thinkpad) has developed a problem with one of it's memory slots. It is an inherent problem with the Thinkpads. The way to tell is topress on the memory cover in a way that pushes the memory (or more to the point, the memory slots) into the motherboard. While keeping pressure on the memory, try to boot up. I use a T30, and have worked on several others, all have at least one slot with this problem. Also try taking out the memory which is closest to the front of the system, and pushing in on the remaining one. Hope this helps. If this is the problem, there are a couple of things you can do to keep it running, but probably with only one ram stick. Goood luck
Posted on Oct 08, 2007
  • jim walenciak
    jim walenciak Oct 10, 2007
    No, I think you have a couple of items happening simultaneously.
    First, keep #1 stick in slot 1 (slot closest to the network mini pci cover, or closest to the rear)the slot closest to the front is consistently the bad slot.
    If you have some foam tape (the kind which is sticky on 1 side and is about 1/4" thick), cut a slice about 1/4" wide, and long enough to run along the memory slot, maybe even covering a bit of the ram.
    Put the cover back on tightly. the foam tape will hold the slot down to the board.
    Then see what you have.
    I think the other problem would be solved by booting from your XP cd, and running a repair (the R after presasing F8)
    Good luck, let me know how it goes, ok?
  • jim walenciak
    jim walenciak Oct 18, 2007
    Well, I'm running a 1 gig stick in my T30, because only one slot works on it. I took it outtoday, put a 512 in, and it also works, where before it was inconsistent booting.
    My guess is, you're going to end up using 1 slot, so find the biggest stick that's compatible. You won't hurt it any more than the poor engineering is hurting itself.
    Good work. Nice visiting with you.
Gateway nv52 laptop cays corrupt registry stuck in recover mode
start computer and lunch startup repeir. you see windows is loding files and you see blue screen read and click next computer will start now
May 31, 2013 | Gateway Computers & Internet
Yesterday My IBM T23 laptop froze..I hit the power button to unfreeze it. It powered down and re started but now it takes about 10 minutes on the Windows XP screen and a good 20 minutes to get to the...
Try to boot up in safe mode this is done by pressing F8 during boot up select safe mode with networking after it has completed and run for a little while reboot up in regular mode.
Hope this helps
Dec 07, 2009 | IBM ThinkPad T23 2647 Notebook
My son's PC *always* needs to be booted twice to get it up in Windows XP Pro. For some reason it hangs during the first boot. Once it hangs you have to push'n'hold the power button to force shutdown, and...
You can do a bit of detective work and run MSCONFIG.EXE froma command prompt and go through that - particularly the boot, services and startup entries. The startup entries in particular - as from there you can select what is and what is started at startup - and a process of elimination can maybe help you track down the problem. 'Registry cleaners' may help - but often are more problematic themselves thn they are 'fixers'. You could edit the registry by hand, using regedit, but that is NOT recommended unless you really know what you are doing. Do note that if you change the start-up programs (i.e. change their enable state), you will get a warning at start-up that you are running a custom start-up using msconfig.
As a last resort, a fresh installation of Windows will fix things. Running a virus checker might also be a good idea.
Nov 03, 2009 | Computers & Internet
Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
Apr 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
T30 cant find os
when you start does it come to point where it shows xp and ibm
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
T30 Will not resume from standby without reboot
It sounds as if your computer is going into hibernation. Check your power management settings to see if keys are enabled allowing a specific key or process to bring computer out of hibernation. Hope this helps.
Dec 23, 2008 | NEC MultiSync FE750 Monitor
Windows XP Pro - LG GCC-4243N combo drive not seeing data on disks
if you have lance cleaner then use it but shyore it one famouse brand otherwise it should damage yor cd om's lance if you found nothing then pls go to your hardware vendor
Jan 12, 2008 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
IBM ThinkPad T30 2366 Notebook Logo
281 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
