Question about 2005 - 2005 Land Rover Freelander Tire Pressure Monitoring System TP
Can't get gears to go down. Unless stopping my freelander will go up fine
Changed clutch and slave cylinder took car our went up the gears fine but not down the gears have to stop to change gears
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
Check your pressure plate
Posted on Nov 18, 2013
1987 saab 9000 turbo transmission
bad pressure plate or stuck throw out bearing.
Jun 06, 2012 | Saab 9000 Cars & Trucks
Have freelander td4 03 plate, continuous problem with clutch. had new clutch , slave cylinder and master 2 months ago, all fine till a month ago lost pedal completely , had new master fittted problem fixed...
Definitely a hydraulic issue. Iknow you said they were both changed, but its usually the master & slave assembly that go faulty on the Freelander. Both parts come filled with fluid and pre-bled and only require fitting, no bleeding. Check with garage to make sure they did not split / bleed them.
Jun 06, 2011 | 2003 Land Rover Freelander
Clutch was slipping real bad, changed gears just fine. Took it to a garage, installed new clutch kit, Drove it home still slipping, so I replaced slave cylinder, great for about a week started slipping...
check the clutch linkage and make sure it'd not binding and di you replace the pressure plate? if not then it will need to be replace to stop the slipping if the linkage is not sticking or jamming. If the pressure plate springs are broke it would cause it to slip, also if the master cylinder is not releasing this could cause it to slip.
Jun 06, 2010 | 2001 Hyundai Elantra
The cluch pedal does not come back up at times and the following time it does not work and consequently cannot swith to a gear on my Landrover Freelander 2003, 2L. diesel. Gilbert
i would change the clutch and while you are at it i would also change the clutch arm and bush as they are prone to seizing causing a stiff clutch action and dropped peddle and slave cylinder failure , slave is plastic and the ears and white coller snap off, when cold if your car feels like its jerking as you move off i would deffently say it is the clutch arm and not the clutch, but as you will need to remove gear box any way i would renew the clutch and thrust bearing.
Feb 13, 2010 | 2002 Land Rover Freelander
Pushing clutch pedal fully down &still difficult to obtain gears
Clutch plate is worn down to nothing and/or throwout bearing needs replaced.
Jul 29, 2009 | 2002 Land Rover Freelander
Clutch problem 1.5 dci scenic 05
you have checked brake fluid.
if ok then clutch.
if fluid low, fill, bleed the slave cylinder and its cured
Jul 02, 2009 | 2005 Renault 181
Rover 600 1997 not engaging any gears when clutch fully depressed
Sounds like the SLave Cylinder has givin up Possible the Reli=eice Bearing I ALWAYS Replace As A PAIR . If you can put in gear by having someone rock the car front to back and it holds well its pretty Obvious that you DO have A Clutch Master Cylinder or Clutch Slave aat Releice Bearing Problem AGAIN These Parts I REPLACE AS A PAIR. Before ANything Chech Fluid Level that will tell the store IF FULL Most Probably MASTER-- If EMPTY then See where it went Look At SLAVE if wet thats the Culpret. --->> I Hope this INFO helps you and have a good Day >> Please dont forget to RATE me ok ? Thank You
Jan 05, 2009 | 1998 Honda Accord
2005 - 2005 Land Rover Freelander Tire Pressure Monitoring System TP Logo
Top Standard Motor Products Vehicle Parts & Accessories Experts
Ron
Ron
Robert Rankin
Gary Nitowski
Are you a Standard Motor Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
