Question about Drills
I have a TE17 that needs a new drill chuck,that I have, but I can't get the old one out, I think it's stuck, how do I remove the old drill chuck? Thanks; Bob
Do I just turn the selection sleeve cc and pull it to release the drill chuck saft?
  • 1,889 Answers
Open the chuck jaws all the way then look inside the chuck using a flashlight and you will see a screw turn it the wrong way as it is left hand thread
Posted on Nov 18, 2013
rowdy45176
  • 2176 Answers
SOURCE: Can't remove old drill chuck. No screww head visible
I can't find that model number in their database but I would guess that the chuck that is on it now is for a non-reversing tool and therefore would not have the hole for the chuck retaining screw. As long as the threads are the same I don't see a problem putting it on. Let me know if I can help further. Dave
Posted on Dec 24, 2008
Chuck68
  • 42 Answers
SOURCE: Chuck broke on my hammer drill
To take a chuck off of your drill open it up all the way.
Inside there's a screw that you have to take out. It has to be turned clockwise to get it out.
You may need to struggle with it a bit because it's usually really on there tight.
Some folks even use a second drill to loosen it up and that's a really good idea if you have access to one.
Once you get the stubborn little screw out, put an Allen wrench in the spot where the bit would fit in.
If you can't turn it--and you probably won't be able to--then try using a rubber mallet to (gently) hit the arm of the Allen wrench to get it to turn.
Then you should be able to just take it out.
Put the new chuck into the drill.
Add a few twists of the Allen wrench in the opposite direction.
Tighten it up good.
Put the screw back in place and also tighten that up good.
The drill has a lot of vibration and if these aren't tight, it'll cause problems down the road.
Your drill, expertly fitted with your brand new chuck, should now be good to go.
Please rate this solution
Posted on Jan 13, 2009
rowdy45176
  • 2176 Answers
SOURCE: Is Hammer adjust collar attached to chuck?
I looked at a old schematic for the 5078 and it appears that it might come off after chuck removed. The chuck is threaded and if you have the 2 speed model, shift it to low and put a bent handle allen wrench into the jaws and chuck on workbench or block of wood with long portion at approx 30 degree angle and strike the handle, you will be hitting it counter clockwise to remove.
Posted on Jul 25, 2009
  • 8 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
  • 13 Answers
SOURCE: Broke bit inside chuck and
TAKE THE OUTER CHUCK PEICES OFF THE IMPACT!! THERE WILL BE A C-CLIP, WASHER, SPRING AND ONE OR TWO BALL BEARINGS AND THE OUTER HOUSING, IN THAT ORDER! WITH ALL OF THAT OFF, MOUNT THE ANVIL IN A BENCH VISE WITH BRASS JAWS OR BETWEEN TWO PEICES OF WOOD, UPSIDE DOWN!!!!!!!!!!!!!!! THE TRICK IS TO HAVE THE BIT FALL OUT OF THE CHUCK ONCE IT IS LOOSE!!!! NOW WITH IT MOUNTED IN THE VICE AND PRETTY TIGHT, TURN THE TOOL ON UNTILL IT FALLS OUT, IT WORKS GREAT IF HAVE DONE IT ABOUT 75 TIMES!! MOST PEOPLE THINK I'M A WIZARD!! BUT IT'S REALLY EASY. WITH IT MOUNTED SOLID IN THE VISE THE ANVIL HITS SO FAST AND HARD IT VIBRATES THE ANVIL, IF YOU DO NOT REMOVE THE BALL BEARINGS HOLDING THE BIT, YOU WILL BE DOING THIS ALL DAY. SOMETIMES, IN THE CHEAPER BITS IT WILL ROTATE AND GALL UP SO BAD THAT IT WILL NEVER COME OUT, IN THAT CASE YOUR BUYING A NEW ANVIL ASSY. JIMS TOOL SERVICE
Posted on Feb 02, 2011
3/8" cordless driver can't change the
If debris enters the chuck it may no longer turn for adjustment. Spray plenty of wd40 into chuck and allow plenty of time for oil to do its magic. Hold chuck/drill pointing down and turn drill in both directions to clean out debris. If chuck is too far gone, remove the center screw (backwards thread) and remove the chuck(threaded on). Replace the chuck with new generic part from Lowes (about $25.).
Sep 20, 2011 | Dewalt Drills
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
Need owners manual for hilti te 17
Owners manuals are no longer available. The TE17 has not been sold in over 30 years. Hilti no longer carries parts for the TE17. I can tell you just about anything you would want to know about the TE17s.
Lube: 30cc if the gear housing is still wet. 50cc if the housing has been washed out.
Older models had the "twist type" chuck. Meaning you would twist the chuck to insert the bit.
Newer versions had the "pull back" chuck.
If you have a black fill cap on top of the gear housing it meant that you did not have a safety slip clutch. If you had red cap then you did.
The armature rode on an oilite bushing which would tend to wear out and cause the armature to rub against the field.
If your 17 is still running then great run it until it quits. The only place to find parts are used ones on Ebay
Feb 24, 2011 | Drills
My chuck is stuck , how do i remove it and get a new one?
There should be a set screw in the center of the barrel of the chuck. Remove it and put in some penetrating oil. The chuck should then unthread counterclockwise if I remember correctly.
Feb 13, 2011 | Makita HP1641K 58Inch Hammer Drill Kit
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Mar 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hi my drill chuck is stuck and will not retract, I think the bearings hve gone. How much will a chuck be to be replaced and repaired?
tricky question the size and the cost is important so .repair drill cost versus new drill?
new drill for me sir.
repair chuck may be good but other parts should be repaired once you are inside the drill which is going to cost more.
Aug 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a very old 3/8'' elecric drill, I think it ia a Skil, The key chuck does not work properly and I want to replace it. How do I remove the old chuck?
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 12, 2009 | Drills
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Chuck Replacement
Hello Mike-To remove the old chuck, you'
ll need to open the jaws all the way and l;ook inside the chuck for a screw that holds the chuck onto the motor shaft. That screw has a reverse thread which means that you'll need to hold the chuck tight while using a screwdriver to turn the screw in the forward direction. After the screw is removed, p[lace a large allen wrench into the chuck and tighten it. Then using a hammer handle, rap the allen wrench in the reverse direction for removal. Then call Alltrade Tools @ 1-800-423-3598, give them your model number so they can provide you with a replacement chuck.
Jul 31, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Drills Logo
83 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
