Question about Panasonic Washing Machines
Panasonic NA148VX3 replace drum bearings
We have a Panasonic Front loading washing machine which I believe needs drum bearings replaced. Machine is noisy on spin and feels a bit rough when you turn drum by hand. No play in bearings yet. I am trying to find out if bearings are easily replaced and available for this model.
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
bestdarngood
  • 3037 Answers
SOURCE: Spin Cycle is very loud on front load washing machine
yes, you can, if you need a place to buy a new bearing, let me know the make and model and I will get you a link to purchase one from
Posted on Sep 04, 2008
SOURCE: Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Posted on Nov 14, 2008
  • 188 Answers
SOURCE: bearing on front load washing machine needs replacing (Frigidaire
You will need to replace the tub rear shell/bearing assembly (part # 131525500).
To do this, practically the whole machine will need to come apart.
To remove the drive pulley, remove rear cabinet panel. Remove the pulley screw and pull back on the pulley (you may need to giggle it as you pull to remove it).
For the shock pins, grab the open end with a pair of vise-grips. On the "pointy" side of the pin press the tab in with your finger (if you can't push the tab in slide a 9/16" socket onto it) and pull the pin out with the vise-grips (twist back and forth slightly as you pull).
A qualified tech could replace the rear shell/bearing in about 1.5 - 2 hrs. I can certainly give you more help if you need it, let me know.
Posted on Mar 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
Washing machine sounds like a jet plane, when spinning
I would suspect that the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise when you spin the drum.
Jan 31, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Awful bearing noise on spin.
Remove drum belt and spin drum by hand, if it is noisy or feels rough, then the main drum bearings have failed, which is a major repair.
Oct 11, 2010 | Bosch Exxcel WFO 2265 Front Load Washer
Washer makes thumping noise when spinning and belt jumps off
I suspect that the main drum bearings have failed.
Remove the belt, and from the front spin drum by hand, if it feels rough or is rumbling or noisy, then drum bearings have failed.
Can be expensive!!!!
Feb 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Machine noiser than it use to be when tub spins
From the front of the washer, spin drum by hand, and if it feels rough or is noisy, then the main drum bearings are probably worn.
Another possibility is the motor bearings noisy, or a worn armature.
If the noise is gradually getting worse, then I think it is safe to say it is the main bearings.
Jan 26, 2010 | Hotpoint WMA40 Front Load Washer
Hi there my machine has gone very loud when spinning,washes perfect,any advice
Sounds like the main drum bearings have failed.
Spin the drum by hand from the front of the washer, if it feels rough, or is noisy or rumbling, then the the main bearings have failed.
A major repair!!!.
Jan 15, 2010 | Zanussi Washing Machines
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Noise when spinning
Remove drive belt and spin drum by hand, if it is noisy, or feels rough, then the main bearings have failed, if no noise, then check for noisy motor bearings.
Please rate my solution.
Thanks.
Jul 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Creda IWD12 makes noise when spinning but still works ok
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
Dec 02, 2008 | Creda IWD12 Front Load Washer / Dryer
Drum is sparking when spinning the clothes
Sounds to me as though the main drum bearings have gone and the drum is catching the internal parts.
I f the drum is turned by hand and it feels rough or is noisy, then it is the main bearings.
Sep 24, 2008 | Creda W120VW Front Load Washer
Washing Machines Logo
258 people viewed this question
Top Panasonic Washing Machines Experts
SteveAlaska
micky dee
richie46
Are you a Panasonic Washing Machine Expert? Answer questions, earn points and help others
