Question about Mad Catz Wireless Microcon For Xbox No. 4586
How to connect controller
I dont know how to connect it i found my xbox that i lost like 8 years ago but now i tried using the contoller but nothing happens
I have been trying to get on facebook now for the last 8 hours. it keeps coming up as connection problems...i know i am connected to the internet though..it gave me 3 options to try which are, 1, refresh...
Hello
First reboot your pc.Then go to control panel .internet options.Clear and delete all cookies and data.
Next,be sure your using the latest version of internet explorer 8.If not it can be found here.
http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
Next use a anti virus program to clean the pc.
Mar 09, 2011 | Computers & Internet
3 days ago i took my 1st player xbox 360 controller to my cousins' home and connected it with their xbox 360 (same model) toplay games with them. yesterday, when i came back home i tried connecting my...
Here are the things you can do to solve the problem.
1. On the front of the controller and the system there is a little button you can press that can connect to each other for you to play.
2. Make sure that the batteries are properly placed inside the battery pack under the controller.
3. Make sure the batteries are not dead.
I know this is not much but I hope this information helps you.
Jan 04, 2011 | Microsoft Xbox 360 Controller
I am trying to connect an xbox 360 wireless contoller to my pc. I have followed the directions to download new software for Windos 7 64 bit but the contoller connects but does not do anything.
if your trying to use the controller to play games on your pc you cant unless u buy the microsoft adapter wireless gaming adapter for your computer, if your trying to just charge it, you just connect the charge cable to your usb drive and windows will automaticly find the drivers.
Apr 13, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox 360 wireless pc controller reciever not working??
My receiver died two days ago, i opened it up, and the Fuse was damaged, dont know how it could happen, not that much of current going thru that receiver, well the thing is all you have to do is get a solderer, and soldering iron, remove the fuse and solder a little cable so that you have a close circuit, The fuse is on the down side of the PCB (Printed Circuit Board), its named after F1
Jul 03, 2009 | Microsoft Xbox 360 Controller
I want to splice a ps2 contoller with an xbox plug, so i can play my xbox with the comfort of my ps2 controller. but my ps2 controller has 8 wires and xbox only has 5 wires, so i need to get a wiring...
As far i know, that is not possible to splice a PS2 controller with an XBOX. As you said they have different wiring sets, so I highly doubt it will work.
Mar 10, 2009 | Sony PS2 Dual Shock 2 Controller...
Xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Jan 18, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless control conects then disconnects randomly
The solution is VERY simple.
There is nothing wrong with your controller OR your xbox.
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. People will find the solution quicker that way.
May 04, 2008 | Microsoft Xbox 360 Controller
Cant connect with Xbox Live
I don't know if you did this or not yet but..Try talking to "Hardware" support. ask for hardware, they may know. just a suggestion
Apr 23, 2008 | Microsoft Xbox 360 Console
Xbox controller will not sync with console
Disconnect the power cord from the 360 for a couple of minutes.
Plug it back in and turn it on. Power turn on a different controller than the one that isn't working and sync it with the 360.
Now turn on the original controller that wouldn't sync, and use the sync buttons on the 360 and controller. It should sync up and go to player 2 slot.
Everything should be good now, that's how I fixed mine.
Mad Catz Wireless Microcon For Xbox No. 4586 Logo
50 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
William Wurtinger
John mullen
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
