Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
Dvd cd-rom Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) that is the message im getting as to why my driver is not working. how do i fix this?
  • Anonymous Dec 11, 2007
    would not read or load a new program to my laptop
  • Anonymous Dec 18, 2007
    Same as lady ash's dvd cd-rom problem. Prblem occurred when switching (Broadband) ISP's for some reason
Gixed the problem using solution provided by Microsoft Support ref 314060 (method 2 - deleting the UpperFilters AND LowerFilters registry entries) as defined in the link:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;314060
My problem is solved hope it works for you guys
Cheers
Superworm
Posted on Jan 20, 2008
  • 3 Answers
Which OS you are used.if You used windows 98 then boot up your pc with bootable windows 98 cd,it loads cd rom driver automatically.
SOURCE:
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
DVD driver is corrupt and can not access my DVD
(Windows 7 CD-ROM Drive & Mitsumi CD-ROM Drive)Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Aug 10, 2010 | Fujitsu Siemens Computers & Internet
Since the driver for all optical units is the same Windows one it means that there's corruption in your system.
Run a full malware scan and after it perform a Repair install.
Jul 07, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
My DVD/CD-ROM drives stop working. On the device manager itb says, Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Hi friend,
Firstly you update the DVD/CD-ROM drives form device manager and restart the system,if nothing happning in that condition you need to reinstall the DVD/CD-ROM drives through CD or net.
Thanks,
Feb 25, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Feb 24, 2010 | Compaq Presario V4000 Notebook
DRIVERS CD-ROM NEC DVD RW ND-2500A
WINDOWS CANNOT LOAD THE DEVICE(DVD ROM) FOR THIS HARDWARE MAY BE CORRUPTED OU MISSING (CODE39)
Oct 30, 2008 | NEC ND-2500A DVD±RW Burner
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
165 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
