Question about Neumann U87 Professional Microphone
Where do I find a replacement bass roll-off filter switch for a u87ai?
The switch is made of beige plastic and has a thin, protruding shaft that has broken off. It still functions as a switch, but is difficult to use.
Paper won't feed into slot on Canon P26-DH 111
Could not find anything directly about a Canon P26-DH III calculator but, here are steps I found for a similar model. Please let us know if this does the trick for your situation or not. Thanks & Good Luck.!
Installing a Replacement Roll
Move the power switch in the upper right corner of the calculator to the "Off" position. (or wherever it may be on your model)
Push the wire roll holder back so it protrudes from the back of the calculator. Place the replacement roll on the holder so the paper's end extends from the bottom of the roll.
Cut the paper's end diagonally and insert it into the slot in the back of the calculator.
Step
Move the power switch to the "PRT" position to turn on the calculator.
Oct 14, 2017 | Canon Office Equipment & Supplies
I have a Sandstrom DAB micro Hi Fi system SHFJMC11 and can not open the door (says door key locked)
just inside the ipod cover you will see a thin black plastic flap that is also the ipod lever, protruding into the door. you need to insert a small thin knife and push this flap back so it clicks flush into it's position. this takes the lock off and you will be able to open the door.
Dec 26, 2013 | Cars & Trucks
Is there a cabin filter?
Yes its under the plastic bulkhead panel that the windshield wipers protrude from . Fiddly to replace, since have to remove wipers to get cover off. Worth doing though. Pretty scary how much gunk they accumulate.
Jul 07, 2012 | 1997 Saab 900
Dear All, We use a 12-years old Neumann U87Ai for male voiceovers, with no problems. Recently we experience some slight but annoying distortion, especially when recording loud male voice with lots of...
Usually the distortion is from over gain on the preamp or the spl of the actual voice on the diaphragm have him step back a few steps and try again.
Good Luck, Cody J.
Dec 16, 2010 | Neumann U87 AI-SET Microphone
I have a Sharp copier MX 2300G.It has developed a problem and it instructs me to call service under this code L4-02
The tray one lift up motor (angles the paper up to the feed rollers) has a plastic shaft that can twist and will need to be replaced. "To enhance the strength of the output shaft gear against twisting, the material of the
output shaft gear has been changed. Along with the material change, the colour has also
been changed from Beige to White." new part number is CCOVP1607FC438
Oct 14, 2010 | Sharp Office Equipment & Supplies
NEED TO CHANGE A BELT
First you need to remove the metal cover to expose the brush roll assembly. Push up the plastic cover connected to the foot pedal to expose the motor shaft. Remove the brush roll assembly and simply hook the belt on the motor shaft first then pull back the brush roll and push the brush roll back to the slot. There's a small piece of plastic on the left hand side of the brush roll. This piece would go in after the brush is set in the slot. Finally, replace the metal cover.
Jun 23, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
No power to my speakers. How do you open the amp? BOSE acoustimass 5 Thanks
A powered AM5 bass unit? Undo the 1/2 screws, tease out the toothed quadrant by 90deg then tap the plastic panel down/away from the toothed quad. not easy the clips are usually very tight.
Oct 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
On the shaft that produce from the Juice Extractor
ONE ACME AND OMEGA IT'S CALLED THE
CLUTCH NUT. GOOGLE THE MFG. OR
FOR YOUR BRAND'S PARTS.
Jun 29, 2009 | Hamilton Beach Juicers
Paper "accordians" just as it should be coming out of the printer
The fuser roll has little plastic pickoffs that guide the paper out. When a pickoff wears through the surface of the fuser roller, you get the issues you are having. Almost all the machines out there now have a fuser unit you can buy to replace the whole thing.
Jan 10, 2009 | Canon imageCLASS D880 All-In-One Laser...
CD Player display always show "Open"
Theres a protruding plastic that pushes the close detection switch inside, the switch might have gotten dirty or reshaped, you can remedy this by adding height to the protruding plastic, or have someone disassemble the unit for you. It can easily be remedied by a technician...
Dec 02, 2007 | Coby MP-CD450 Radio/Cassette/CD Boombox
Neumann U87 Professional Microphone Logo
41 people viewed this question
Top Neumann Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
drivealot
Are you a Neumann Audio Player and Recorder Expert? Answer questions, earn points and help others
