Question about Toshiba Electronics - Others
My toshiba 8g pendrive can't format - Toshiba Electronics - Others
My 8 gp toshiba pendrive has been converted into 4 mb . what should i do now?
FORMAT IT WITH FAT32 (DEFAULT)
OR
MY COMPUTER > CLICK THE PROPERTY OF PEN DRIVE > READY TO BOOST (TAB) > DO NOT USE THIS DEVICE > OK
Aug 07, 2013 | Toshiba Electronics - Others
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
I have 8gb kingston pendrive..and i set my pendrive drive name to 'myname'.i already used my pendrive 7.4gb.and got a lots important files..when i plug in the pendrive,it will automatic install driver...
yes your pendrive is attactked by a severe virus.......you need format it you can do only one thing click on format option or restart the pc then press f8 thenan stat windows setup when you reach the formatting option then only format that pendrive.............
Nov 27, 2010 | Computers & Internet
My kingston 32gb pendrive not format , how to format my pendrive please give me step by step solution thanks & reghardes subhash
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
Apr 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pendrive not formatted
if u still having the same problem, follow these steps:
1.Insert your pendrive. open mycomputer, note the respective drive showing pendrive.
2. Then go to run and type cmd ( or go to command prompt)
3.It will show like: C:\> or C:\Documents and Settings\UserName>
4.Type the drive name of pendrive as shown in e.g
if drive is h: then type as
c:\>h:
h:\>format h:
it will format and ask for media name, you can give the name of your pendrive.
your pen drive is formatted. Now it will show the free space as 8G.B
Sep 13, 2009 | Transcend (589307) Media
HOW TO REMOVE WRITE PRTECTED OR AUTORUN.INF FILES
removing write protection in pen drives is impossible..because tht is due to some hardware problemsi and no software can remove writ protection..anyway try this..logon to a linux machine(i prefer ubuntu )
and in terminal route to your drive and type sudo chmod-R 777/media/ and press enter..if one failes to delete files again..then throw away the pendrive.he heh..!!
Jun 15, 2009 | iLO (2 GB) MP3 Player
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded: Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
Jun 02, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Problem with my pendrive
Rather than double click to open drive right hand click and press open!
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
8G memory card
you bought a fake memory stick. return it.
Jul 19, 2008 | Sony PlayStation Portable (PSP) Console
Electronics - Others Logo
32 people viewed this question
Top Toshiba Electronics - Others Experts
Willem.
Willem.
Andrew Wright
Steve
Are you a Toshiba Electronics - Other Expert? Answer questions, earn points and help others
