Question about GE Ovens
We have a Westinghouse Gas Oven 474 Model number GON474SNG Model it turns on and after a short while just turns off any ideas ??
Keeps turning itself off after a short period of cooking
  • 883 Answers
SOURCE: My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
Posted on May 24, 2007
  • 114 Answers
SOURCE: gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Posted on Oct 10, 2007
  • 183 Answers
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Posted on Nov 17, 2007
SOURCE: Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Posted on Mar 16, 2009
SOURCE: Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Posted on Jan 12, 2010
I have a kitchenaid model kgrs505xss double oven. The flame in the bottom oven comes on and burns for a very short time, then turns off before the oven comes up to temperatures. What is wrong?
Any gas cooker has a thermocouple that keeps the gas valve open; if the thermocouple no longer generates current (which feeds the coil of an electromagnet) then the gas valve closes and the flame will go out. So check thermocouple. In normal conditions the voltage generate by the thermocouple is low but the current is high.
Nov 14, 2017 | KitchenAid Ovens
When i turn either the grill or oven knob the oven trips the breaker
Sounds like a direct short,check oven electrical wiring,a lot of times problems can be spotted visually,burnt connection,wire loose touching metal,
Jan 15, 2015 | Ovens
The power keeps going off to the clock and the oven turns itself off
That is an ongoing problem with that model oven. It is the circuit board that is to blame. If the unit is still under warranty, call New World for the repair. If it's not, you will need to replace the board yourself.
Oct 17, 2011 | New World G70m Gas Double Oven
Hi I lost my manual guide so I don't how to turn the oven on. Please give any idea to use the oven
As I'm unsure of your oven model, I can only give general instructions.
Look for a dial or switch that indicates temperature and turn it on if your oven is electric.
If you have a gas oven, you may have to turn a dial and push it at the same, this is to produce a gas flow. If it makes a "clicking" sound it has peizo ignition and will light itself.
If there is no sound, look in the oven for a lever (usually on the floor) and pull it. This will produce a gas flow which you will have to light with a match. Usually you place the lighted match over an existing hole in the oven floor and this will light the oven. TAKE GREAT CARE!!!! The hole is usually at the back of the oven whilst the lever is usually located towards the front of the oven!
I hope this is of some assistance.
May 08, 2011 | Ovens
Westinghouse gas over GON474SNG
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 14, 2010 | Ovens
Burner switching itself off and on.
The heat cycles to maintain an even temperature.
Jan 28, 2018 | Ovens
If i turn on the oven the pilot burns but no gas
This is a bad gas valve. You will need your model number off this unit to order the correct part. If you will look around the front frame of the oven, there is a serial plate with model number on it. If it has a bottom drawer, it may be on the front frame when you open the drawer. Give us a call with your model number and we'll get the right part out to you asap. 972-859-0929 - We look forward to working with you! Hope this helps!
Oct 03, 2009 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Nov 21, 2008 | Ovens
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Ovens Logo
23 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
