Question about Weiser Lock Locks & Locksmithing
Key pad will not work at all
The key pad got full of driving rain against it. Water in the pad???? Would that make it stop working and if so can I dry it out with a hair blow dryer?
  • 1,889 Answers
Soak the lock in a container of 90% isopropyl alcohol you can get this at a drugstore for about a dollar a pint then let dry in the sun.
I take these apart and spray the parts with alcohol but only try this if you think you can put the lock back together again correctly
Posted on Nov 18, 2013
My keypad stopped working. Is there a battery for this?
if your keypad is factory installed there is no battery . if after market yes has battery. if factory, be sure no keys are in car, when you press in a code number does the pad light up ,if yes its getting power then it is probably the keypad needs to be replaced ,if not lighting up its not getting power, check fuses and wiring connections
Dec 23, 2014 | 2005 Ford Escape Limited
Peugeot 307 problems forum
No idea here as this is new technology i havent come up against as YET but their must be a way of disconnecting this function
May 03, 2014 | Cars & Trucks
1999 boxster, heavy rain triggered flasher, wont start
Check under drivers seat, the immobilizer could be full of water.
easy to remove and dry out.
Feb 10, 2014 | Porsche Boxster Cars & Trucks
When is raining and i drive it on to the water it stops and dont start. even if starts it the engine doesnt run properly..the next day ..no rain ..the engine work perfectly..
Change your distributor cap, rotor, and spark plug wires. This should be enough to prevent stalling in the rain.
When these components wear out, the problem is first noted when driving in the rain. If they are not changed, eventually the car will not start, even in good weather.
Jun 09, 2011 | 1991 Toyota Previa
Water Damage in blackberry
i have a pantech slate and it got full of water,.....i put it in water & that didnt work so i tryed a hair dryer....now it works perfectly fine
Mar 30, 2010 | AT&T Blackberry Curve 8300 Smartphone
Breaks
It sounds like you need to change and brake pads and rotors. You may have worn the pads low enough that the rivet that hold that pads are now up against the rotor. Same goes for the rear if that is where the gringin noise is coming from. Good luck a safe driving
Apr 07, 2009 | 1994 Ford Econoline
Wiper Motor problen
Most likely this is caused by something binding or water getting inside the motor,either way it is tripping the thermal overload inside the wiper motor.
Oct 22, 2008 | 1995 Buick Park Avenue
Weather related electrical problems
I had this problem with mine. Do not ever use a automated car wash on your ALERO----it destroys the seal around the window. Then, when you drive in rain, water leaks into the fuse box, shorting it out. I had to replace the fuse box ($500). Hope this helps.
Jul 23, 2008 | 2003 Oldsmobile Alero
Locks & Locksmithing Logo
53 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
