Question about Epson Office Equipment & Supplies
Xp 200 paper jam
Changed one ink cartridge and wont let me print
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
aicaxz
  • 511 Answers
SOURCE: EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Posted on Jun 13, 2009
professor_sc
  • 180 Answers
SOURCE: HP psc 1310 - gave paper jam and print cartridge
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Posted on Oct 28, 2009
SOURCE: dell 926 photo printer will not print black ink.
I'm am having the exact same problem with a new Dell 926!
Posted on Feb 16, 2010
Wont print photos - paper comes out blank or message saying no paper (when there is) or paper gets jammed.
Its very difficult to answer a question with limited details
1. WONT print photos ( is this an Ink issue Have you checked ink levels and have you gone through the ink cleaning methods ie cleaning clogged heads, Nozzle checks 90% of the time the reason why printer is not printing correctly is because the nozzle or heads are blocked, And sometimes it can be the ink cartridge itself that is faulty.
Again with the paper issue it does not take much for a paper Jam alert to pop up disconnect turn printer round use big light and double check there is no snags of paper trapped in there if you have a compressor which is ideal for blowing out paper dust and snags
Again with limited details it hard to advise but I hope this helps
Feb 24, 2015 | Epson Stylus Sx438w
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
How tochange the ink cartridge
Open 'Printer properties' and go to 'Maintenance' page. There should be a button called 'Replace ink cartridge'. Click on it and follow the instructions...
Alternatively...if a cartridge is already indicating 'empty', opening the printer lid (with printer power on) should move the cartridges to the 'change position'. Replace the cartridge and close the lid when finished.
Aug 25, 2014 | Epson Expression XP-200 Inkjet...
Error message that paper jam in paper cradle
Try this:
  • open the lid of the printer (from where you can see the ink cartridges);
  • remove the ink cartridges;
  • use warm water and cotton swabs to clean both the ink cartridges and the print head (where the cartridges sit on) off of any ink residue;
  • place the ink cartridges back into the printer and test if this works by printing something.
If you're still having issues, there may be a mechanical problem; in which case you need to get it repaired by someone.
Oct 18, 2012 | HP Photosmart 8250 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink absorber full so printer wont print
yes, printer wont print and see screen message
Use this method below with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Use MPTOOL to reset waste ink absober full on pixma mp160.
Download your Mptool first http://www.ziddu.com/download/8524406/MPTool.rar.html
Download manual guide how to use Mptool on pixma mp160.
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help......
Jul 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Our printers epson c42ux red light is on stand still
A permanently on red light can mean several things. If the green light is also ON, it means that you heve no paper loaded, an empty or faulty ink cartridge, or a jammed paper feed. I presume you have loaded paper. You say you have changed the ink cartridges. Note that BOTH cartridges must have ink for the printer to work. The simplest way to check this, or to check for a faulty cartridge, is to try another new set of cartridges - compatible cartridges are very cheap on EBay - about £3 a set in the UK.
To check for jammed paper, remove the paper from the sheet feeder and look carefully inside it, and inside the printer (lift the lid) for scraps of jammed paper. Remove any you see. Press the ink/paper feed button and see if it goes through a paper feed cycle. Reinsert the paper and try it again. If it works, turn the printer off and on again, and it should now be OK.
If the green light is OFF, it means you have a Carriage problem, i.e. something is fouling the print head when it tries to go from side to side. Check this with manual movement. Turn the printer off. After a few seconds, turn it back on again. As soon as the print head moves, pull the power cord out of the back of the printer. You should now be able to move the print head across to the left side (gently!) by hand, then move it back to the right and see if it will go fully into its parking bay at the right hand end. You should be able to tell if someting is hindering its movement anywhere.
Please report back with a new comment if none of this solves the problem.
May 31, 2009 | Epson Stylus C42UX InkJet Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
