Question about Refrigerators
Mitsubishi elegance MR 51E GY, The freezer and refrigerator are functioning, but water accumulated at the refrigerator compartment. What went wrong?
2 Suggested Answers
  • 83 Answers
SOURCE: The mitsubishi fridge thermo damper
Hi
These units are called frost free, however in my experience they are some of the time but not all. It is likely that the freezer has built up some ice around the coil and the fan which migrates to the fridge, try the following.
1. Empty the fridge and freezer and store the food elsewhere.
2. Switch off and unplug the unit and leave for 24 to 36 hours with the doors held slightly open. You may get quite a lot of water on the floor, you just need to mop it up, this is normal.
3. Wipe out the inside of both sides to leave them clean and dry.
4. Plug in and switch on, wait around 4 hours.The vent will be clear.
5. Re stock the unit it should be OK.
6. If the problem re-occurs within a few days then there is another possibility that is causing this problem and that is there may be a fault with the defrost system. Possibly the timer, the termination switch or the heater.
7. If the problem goes away for several months then the ongoing solution is to repeat the above steps.
Regards
Gordon
Posted on May 05, 2011
Water collects in refrigerator which is below freezer
use air from bottom of fridge, but you will have to clear top drain eventually
May 04, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
The mitsubishi fridge thermo damper clog with ice and the fridge is not cold . The ice freezer compartment side is ok. Please advise what is the problem. The model of the fridge is MR -51E -GY. Thanks
Hi
Regards
Gordon
May 05, 2011 | Refrigerators
Water accumulating and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
