Question about Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0
How do I change the O-Ring on the Ladylux Sprayhead Kitchen Faucet?
snap101
  • 117 Answers
SOURCE: I have a Grohe Ladylux Plux kitchen faucet that
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
Posted on Aug 04, 2009
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
  • 112 Answers
SOURCE: Just purchased a Ladylux faucet
Do you have good water pressure in rest of house if not you may have to put a pressure booster system in. if you do there may be a water saver washer in the end of the hose on the faucet,you can disconnect the hose and if there is a washer with small holes in it you can take that out(you may have to put some type of hose washer back in the hose so it dosen't leak).
Posted on Jun 13, 2011
jyackle5
  • 8197 Answers
SOURCE: I just replaced the sprayhead
On the link below. Page 3 will show you haow parts go on your faucet.
http://www.groheamerica.com/lib/1/tpi/1311700.pdf
Posted on Jun 18, 2011
  • 397 Answers
SOURCE: Water flow from grohe ladylux kitchen faucet has
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Posted on Jun 28, 2011
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
How do I set the spring tension on a ladylux kitchen faucet with pullout spray
Personally, I didn't think it was supposed to. I assumed the spring was a form of stress relief for the hose as it nears the pass-through.
Sep 12, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
How do you remove the spray head from the supply line on a Grohe Ladylux?
Ok not sure what you are asking , but here it goes. If you are wanting to take off the sprayhead simply pull the sprayer out and unscrew. If you want to remove the spray hose from the bottom of the faucet simply grab the red spring loaded connector near the TOP, and pull down spring to release (kind of works like an air hose quick connect). If you want to remove the arch the hose must be removed from the faucet first, then simply jerk up on the arch to remove. When the arch is removed, there is a specialty tool that came with the faucet (which most plumbers keep) to tighten or loosen the faucet. Hope this helps. Luckydog
Jun 03, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Just purchased a Ladylux faucet for my kitchen sink and want to know if there is any way to strengthen the water pressure (water stream). It is too weak for kitchen use. Please advise at your soonest as...
Jun 13, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Logo
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
