Question about EFUN NextBook NEXT8P12 8" Tablet
Manual for nextbook next8p12 - EFUN NextBook NEXT8P12 8" Tablet
Unable to download anything keep being told insufficient memory.
Start by checking storage space available. some older versions of android have a nag of accumulating useless data in some corners of the system. You may not be able to see what uses the space, but at least it will tell you if there is space or not. To help you, i need to know if there is actually any storage left or not.
This can be found in "settings -> storage"
Note: Internal storage = the onboard storage from the factory. memory is the RAM, nothing can be saved here. So if you have an EXTERNAL micro sd put in, please provide this information.
Apr 12, 2016 | Nextbook 8" LCD 1GHz Processor Wi-Fi...
I can't get it to charge, maybe by batter is getting old?
Very probably it's your battery but also might be the charger or even the cable of the charger. You should first check your charger, it can be done with an electronc tester at any electronics repair shop.
Just as illustration, I had a problem charging my iPad 2 and it was THE CABLE; it was apparently perfect but the problem was solved simply by replacing it.
Jul 05, 2015 | EFUN NextBook NEXT8P12 8" Tablet
Where can I get a manual for the nextbook model NX700QC16G
I Googled "Nextbook 7 Users Manual" and came up with Nextbook Premium7 NEXT7P Manual User Guide Troubleshooting . 2/3s down the page after DOWNLOAD you can download the Tablet Manual in PDF form for free. If you had taken a little time you could have done this.
Jan 01, 2015 | Nextbook Tablets & eReaders
Why does my nextbook 8 when fully charged show an exclamation point in the battery? and when I unplug it it totally drains the battery?
Can mean the battery isn't communicating its status to the tablet--failing battery, bad connection, etc. Talk to tech support for a replacement if it's still under warranty. If it's not and you can still charge it to 100%, hang on and hope for the best.
Aug 12, 2014 | Nextbook 8" LCD 1GHz Processor Wi-Fi...
How do i do a hard reset
remove memory card while off , look for pin hole on side , use a toothpic its that small . power up while holding it
Jun 26, 2014 | EFUN NextBook NEXT8P12 8" Tablet
Screen wont turn back upright
Swipe down from the top. A band of icons appears. Look for the rectangle (top left I think) This is the Screen Lock Icon. Tap it to turn screen Lock OFF. (Or on the EFun it may be a Wheel icon for screen lock.)
Jan 20, 2014 | EFUN NextBook NEXT8P12 8" Tablet
How to get google play app on tablet
it gives me my two phones displaying where it says device. neither of them is it. i caanot input the correct device. it will not allow me to do so
Apr 11, 2013 | EFUN NextBook NEXT8P12 8" Tablet
EFUN NextBook NEXT8P12 8" Tablet Logo
79 people viewed this question
Top EFUN Tablets & eReaders Experts
Are you an EFUN Tablet and eReader Expert? Answer questions, earn points and help others
