Question about York Furnace Draft Inducer Blower Fasco # A224
Fasco A225 I installed a new Fasco A225 into my York furnace. It worked for four days and now I am getting the 3 red lights again (stuck pressure switch). I uninstalled and reinstalled it and then it worked again for a few days and now it isn't working again.
SOURCE: York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Posted on Dec 04, 2009
Testimonial: "Believe have now pin pointed it to weak inducer motor.Removed outside exhaust vent apparatus with three elbows in it. Put one elbow back on .no more "
  • 221 Answers
SOURCE: furnace wont light. have replaced heat rod and
Have your gas supplier verify delivery pressure. Too high or low, the valve will lock up. Should be a free service.
Posted on Dec 30, 2009
  • 760 Answers
SOURCE: had a no heat call
Make sure there is water in the drain trap. If the drain is "WIDE OPEN" the fan can draw air from the trap and not from outside, and the pressure differential will not be enough. This happens as the trap dries out over the summer, then when you start the furnace, the condensate drain from the fan is dry.On some furnaces this trap is a square box,anyway fill that tubing till you see water running to drain.If you read your manual it should tell you to prime the trap. Position of the switch, shouldn't matter, as it is s diaphragm that the vacuum pulls on to engage the switch. You're probably close to the setting, and by just moving the switch, made it operate.
Posted on Oct 17, 2010
heatman101
  • 43501 Answers
SOURCE: I have a York 80
From what you are saying the circuit board has gone bad... the relay that turns on the power to the inducer must have went bad. You will need to buy a new circuit board and replace the old one. Be sure to make all wires or change them over one by one so that you keep track of where they all go...
This is a very common problem and finding a new circuit board should not be hard.
Good luck!!
Heatman101
Posted on Nov 05, 2010
  • 6 Answers
SOURCE: I have a York Gas
These pressure switches are safety features on ALL new furnaces, if replacing the switch didn't solve the problem, you might want to make sure there is no blockage in the exhuast pipe like a birds nest, anything that would restrict airflow, is there inline fan motor in the exhaust pipe ? perhaps it's not working also.
Posted on Jan 23, 2011
Testimonial: "Thanks"
York diamond 90
The problem could be clogged hoses or hose connections or a bad pressure switch. Remove one wire from pressure switch start furnace as soon as inducer fan starts reattach wire if furnace runs replace pressure switch.hope this helps
Dec 11, 2013 | Heating & Cooling
I removed my Fasco 7021-11577S when the bearings went bad and ordered the A225 OEM replacement. I notice that when mounted this new draft inducer it whistles really loud .Is the hole in the back of the...
There should be a gasket between the mounting flange of the inducer motor and the furnace. If you do not have that you can use a small bead of blue or red silicone caulking to seal it. Hope this helps you. Thanks
Mar 29, 2011 | York Furnace Draft Inducer Blower Fasco #...
I have a York Gas Furnace that is 6 months old. The furnace will run for 5 hours like it should and then shuts down. I get 6 red light flashes. According to the manual the presure switch is bad. I...
Jan 23, 2011 | York Furnace Draft Inducer Blower Fasco #...
Had a no heat call the other day on a York GY9S080B12up11a. unit was off on code 3, pressure switch. differential switch is rated for -1.2. hooked up the manometer and was getting -1.2. still wouldn't...
Oct 17, 2010 | York Furnace Draft Inducer Blower Fasco #...
York gas furnace doesn't come on at all. It has electronic ignition, thermostat seems ok, circuit breaker Ok. There is nothing going on at all. It doesn't try to light.
First find the electronic control board. Is the diagnostic light on and flashing a code? If not look for the automotive type fuse on the board. It is a 3 amp. Is it blown? Next look for a screw in fuse in the ssu switch on the side of the furnace. Is it blown? If all the fuses are good is the door switch behind the front cover working? Is the door properely installed? If all these items are working, you should have power to the furnace. If these items are ok, check for 24volts at the transformer. Check the terminals not black and white. If you have voltage there, remove the red and white thermostat wires on the control board. Next take jump wire and jump the red and white terminals. This rules out the stat and stat wiring. Your furnace should start. Check the status light for any further problems and crossreference the flashing light code to fix.
Mar 08, 2010 | York Furnace Draft Inducer Blower Fasco #...
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Just replaced inducer motor, runs great but furnace will not ignite
Check the pressure switch and the little hoses going to the pressure switch. If the pressure switch does not get a vacum from the blower it will not let the furnace light.
Heatman101
Mar 03, 2010 | York Furnace Draft Inducer Blower Fasco #...
York furnace model p2mpd12h06401f flashes 4 times for trouble code does'nt have code list inductor motor comes on but ignitor does'nt come on
Check pressure switch for inducer motor. If switch closes, check for crack in ignitor. If gas valve opens and you can hear/smell gas, the ignitor is bad probably. If pressure switch isn't closed you need to check for blocked vent/chimney/heatexchangers.
Dec 18, 2009 | York Furnace Draft Inducer Blower Fasco #...
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
York  Furnace Draft Inducer Blower Fasco # A224 Logo
78 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
