Question about Garden
On the toro lx425 there's an ignition fuse which is located by opening the hood and looking on the right hand side next
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Posted on Nov 30, 2008
  • 203 Answers
SOURCE: How do I get instructions on replacing both upper
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Posted on Oct 25, 2009
  • 7 Answers
SOURCE: lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Posted on Aug 17, 2010
  • 640 Answers
SOURCE: how do i adjust the
On the right side of your mower you should find a lever that allows you to adjust the cutting height of the deck up and down.
I hope this helps, if that is not sufficient just reply for some clarification and I will answer you question further.
Posted on Jul 15, 2011
Where is a fuse location for 2002 toyota sequoia
Right next to front hood opener, on the left hand side under the dash. ( emergency brake is right under it )
Oct 11, 2014 | 2002 Toyota Sequoia
Where is the spark plug located on a Toro LX425 Lawn mower ?
look for a large black wire on the front of the engine and the end that has a rubber boot on the end pull that off the plug is under there
Apr 07, 2012 | Garden
TURN KEY AND NOTHING, EVERY THING WORKS RADIO,HEATER AND LIGHTS, BUT NOTHING UNDER THE HOOD NOT A SOUND. THE CAR IS A 1999 CAVALIER
Open the hood and look for the engine compartment fuse block next to the driver's side firewall. Open the cover in order remove and inspect the fuse closest to the radiator labeled ING (Ignition) to see if the fuse connection is visibly broken or blown. If it is OK open the fuse panel located at the left end of the instrument panel inside the vehicle. To open, push the tab on the access door to the left and pull the door forward. Remove and inspect the two top right fused labeled IGN and PCM/IGN to see if the fuse connection is visibly broken or blown. Replace any defective fuses and try to start the vehicle. If it starts it could have been a bad connection or a more serious problem requiring service if the fuse keeps blowing. If it does not start it could be the ignition switch or starter.
Jul 27, 2010 | 1999 Chevrolet Cavalier
Lx425 has grinding noise but won
Jul 14, 2010 | Toro Garden
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
Oct 25, 2009 | Garden
Where is the fuse for the ac blower motor in a 2003 Hyundai Santa Fe" The fuse panel under the driver side dash does not list it.I also checked the power panel under the hood next to the driver side strut....
dear friend the fuse that you are looking for is in the engine compartment,if you open the fuse box look to the right hand side,right at the bottom,there is a 40amp fuse marked BLR,that is your blower fuse
Sep 21, 2009 | 2003 Hyundai Santa Fe
My Toro LX425 keeps on blowing 20 amp fuses when I am mowing the yard. Why is it doing that?
a fuse will blow if: a positive wire is being grounded to the frame or two much current is being passed thru it.
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro LX425 wiring harness
The blades themselves don't really matter. If the hood has a safety switch, then all you need to do is bypass it with a jumper wire. Other than that, you should be all set.
Feb 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lx425 rider mower wont start
Oct 05, 2008 | Garden
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
