Question about DeLonghi EC155 Espresso Machine
Delongi EC155 problem with making single coffee
Hi, I just purchased the DeLonghi EC155 machine. I made my first coffee and cappuccino using the 2 cup filter and it was just perfect. However, when I try to make just coffee with the 1 cup filter nothing comes out...everything is mushed when I remove the filter holder. Even though the machine is brand new I cleaned the filter but still nothing comes out of there. What am I doing wrong? Please help. Thanks
  • Anonymous Sep 18, 2009
    I have the same problem too and looks like my brew pressure is considerably low compared to when I got the machine a couple of months back, BTW, I cleaned the machine as per the instructions i.e. using the both the commercial and the citric acid method but there is no improvement. Hope somebody can help us.
    Anonymous
SOURCE:
  • 3 Answers
SOURCE: DeLonghi EC155 Expresso Maker
THE PROBLEM IS THAT YOU HAVE TO STOP THE MACHINE ONCE YOU HAVE ENOUGH IN YOUR CUP . IS NOT A COMERCIAL MACHINE THAT WOULD GIVE THE RIGHT AMOUNT AND THEN STOP ....
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: Problems with handle alignment
I DON'T THINK YOU ARE GETTING A GOOD SEAL ON THE PORTAFILTER . YOU HAVE TO MAKE SURE THERE IS NO COFFEE AROUND THE EDGES AND EVRYTIME YOU ARE DONE BREWING RUN SOME WATER INTO A CUP WITHOUT THE PORTAFILTER IN PLACE .
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 218 Answers
SOURCE: coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
Posted on May 28, 2009
for a single shot of espresso I hold for about 17 - 20 secs and then turn of the machine and this machine does not shutdown automatically.
Posted on Sep 18, 2009
Tip
DeLonghi EC155 Doesn't Release Water
When I bought my EC155, I heated it up for 30 minutes and tried multiple times to run water through. After multiple attempts the water level remained unchanged. <br /> I was able to fix the problem by opening the bottom of the machine (4 star screws). After opening the bottom, I immediately noticed that one of the plastic pipes was not in the channel in which it was supposed to be and as a result was kinked and sealed off. I simply pushed it into the channel and that fixed the problem.
on Sep 14, 2011 | DeLonghi EC155 Espresso Machine
Ec155 delonghi
if you have an ohmmeter, disconnect the cables that feed the resistance and connects the ends of the meter should give a value of element 5 to 30 ohm, if you give infinite that is very high due replacement it, there are also two thermostats one limit and a control, if you use this meter their connections resistance removing the cables connecting them, the measurement should be 0, if it gives you another value or infinite must change.
Feb 09, 2014 | DeLonghi EC155 Espresso Machine
Coffee stops flowing
Run a 50/ 50 vinegar & distilled water solution through it. Only use distilled or bottled, purified drinking water from now on.
Feb 17, 2013 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
I NEED A MANUAL SO I KNOW HOW TO USE MY dElongi Espresso EC155
You can download the user manual directly from Delonghi from this link
Sep 28, 2009 | DeLonghi EC155 Espresso Machine
Feb 18, 2009 | DeLonghi EC155 Espresso Machine
No manual
OK, problem solved! The manual can be downloaded from Delonghi UK customer services http://www.delonghi.co.uk/pdf_files/BAR14.pdf
Yay! Can now make my cappuccino :-)
Jan 05, 2009 | DeLonghi BAR 14 Espresso Machine
DeLonghi EC155 Espresso Machine Logo
153 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
