Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Remove dust cover off riding lawn mower - Husqvarna 23 Hp 48" Deck Yard Tractor
4 Suggested Answers
  • 3074 Answers
SOURCE: I have a GTH 200
1) Use a pair of pliers to grab the entire boot, then careful pull it off so you don't tear it.
2) Use a flat tip screwdriver to remove the C clip
3) Remove the wheel by lifting forward and off.
Hope this helps Tim
Posted on Apr 19, 2011
  • 14 Answers
SOURCE: Husqvarna Riding Lawn Mower 46 Cut model
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Posted on Jul 17, 2011
  • 12 Answers
SOURCE: adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
Posted on Jul 02, 2012
How do you remove the front lens to clean out debris or remove the headlight assembly on a 2006 John Deere 125 riding lawn mower?
under the hood i believe there are small plastic tabs you can push on to remove the cover to clean. be care full as jd has brittle plastic parts.
Oct 24, 2016 | John Deere Garden
How do I replace the rubber priming cover on an ALKO 620 lawn mower?
what kind of engine brigg and stratton or tecuseh what horse power
Sep 10, 2014 | Garden
How do I take a front tire off a craftsman lawn mower
pop the dust cover, if it\'s rubber it\'s a pain... then remove the cotter pin holding it... model number would of gotten a better answer
Aug 26, 2014 | Craftsman Garden
My 22 hp craftsman riding lawn mower gets really hot after10 to 20 minutes and backfires and loses power
You may have a mouse problem. Check the shroud (motor cover) to see if there is shredded paper or other material under shroud. If the mouse shreddings get in the fins on flywheel it will cause the engine to overheat. Remove shroud and clean underneath.
Sep 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler lawn mower wont start just backfires
remove the valve cover and make sure the valves are working
Jun 24, 2012 | Mtd Cub Cadet 46 In 20 HP Kohler...
Poulan pro 300ex riding lawn mower
pull the top cover and see if the starter gear broke if so napa has them for about $10
May 06, 2012 | Garden
How do I remove the Starter off a 1999 Mastercraft 15.5Hp Ride-On Mower
remove the upper engine cover then the twp bolts that hold it to the side of the engine
Apr 14, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Need to know how to change front dust cover on Husqvarna 5521Ch. Can get wheel off; but then I am stumped where to go from there.
Locate and remove the E-Clip that holds the pinion gear (the steel gear that drives the wheel) on the transmission shaft then remove the pinion gear. That is all you need to do to replace the dust cover
Sep 26, 2009 | Garden
Flat front tire need to remove from craftsman 13.5hp ohv riding mower
Remove the plastic dust cover, remove the E clip holding it on the spindle, remove the spacer/thrust washer, slide wheel and tire of
Sep 09, 2009 | Craftsman Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
