Question about Cooktops
Kenmore model c970-404521
Element wont work but indicator lights up and wont go off. all other elements are working fine.
the dr
  • 447 Answers
SOURCE: stove problem - outer cirlcle of an expandable element not working
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Posted on Mar 16, 2008
  • 10865 Answers
SOURCE: one surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Posted on Mar 18, 2009
  • 5603 Answers
SOURCE: Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Posted on Oct 27, 2009
SOURCE: two elements not working
First of all, are you sure it is the elements and not the controler? To test the elements, lift theplate out of the worktop, change the 2 wires from a good element to that element. put the plate back in it is home and use the good elements touchtronic button to turn on the element. I am willing to wager that it is the control unit and not the elements.
Posted on May 03, 2010
Kenmore range indicator light for element does not shut off
Tempature probe(Temp sensor) on that burner is malfuncting . Replace that probe.
www.searspartsdirect.com/partsdirect/brands/kenmore-parts
Jun 30, 2014 | Kenmore White Electric Stove
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
Lower element in Kenmore electric range does not work.
remove and take to appliance shop and they will match up for you. Make sure power is off before doing.
Feb 01, 2010 | Cooktops
Rear left element won't light. Three other
Sounds like a bad element or a switch. It is one or the other.
Aug 06, 2009 | Magic Chef Cooktops
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
One surface element went dead.
Mar 18, 2009 | Cooktops
Wiring new cooktop
no , wiring at endicator light loose probable or deffective indicator bulb
May 11, 2008 | Frigidaire FEC30C4 Electric Cooktop
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
57 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
