Question about Garden
Poulan WT200 wont run with choke off
With the gas at full throttle and choke fully closed the blower will start right up but at low RPMs. As I attempt to open the choke the blower stalls.
SOURCE: Poulan wt200 "wildthing" gas leaf blower
no compression wont start
Posted on Oct 16, 2008
SOURCE: blower starts with a full tank of gas then stalls
The fuel cap has a rubber air bleed valve to allow air into the tank during running. My blower ran for about 5mins, then slowed down and stopped. When I opened the fuel cap, you can hear an air rush, indicating low pressure in the tank which starves the engine of fuel. Problem was solved by clearing the blockage in the cap.
Posted on Jun 18, 2009
bbreton
  • 437 Answers
SOURCE: mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Posted on Nov 02, 2009
SOURCE: craftsman gas leafblower
I just worked on my craftsman leaf blower that would only run at half choke. I tried cleaning the carb and also cleaned the exhaust port. Didn't help. Then i took the cover off and noticed that one of the head gasket bolts was loose. Tightened the head gasket bolts and then it ran fine. Must have been sucking some air.
Posted on Aug 01, 2010
rycgl
  • 1545 Answers
SOURCE: Ryobi CS30 Trimmer starts and
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
Posted on May 22, 2011
Primer bubble wont expand poulan wt200
you have a clog in the line clear lines out and will work right line to tank and to motor both.
Mar 20, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
Nov 05, 2011 | Poulan 25CC Gas BlowerVac
POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Jan 05, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
GBI 20 Weed Eater Blower ran out of gas and will not restart What to do to restart?
somewhere on it is a primer button pump it a few times and choke the blower it should start
Sep 18, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Needs carburator adjustment for poulan model # FL 26
Sure. (This will void your warranty and bypass smog requirements!) There is a red and a white limiter cap on the carburetor adjustment screws. Red= High speed / White = Low speed. Remove limiter caps. Turn both jets a 1/2 turn counter clockwise, Start, then fine tune. Use the low speed and idle screws to smooth out low to idle speed and the hi speed jet to tune the full throttle.
Apr 08, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
