Question about Home Security
How to do a factory reset on a dragon touch sentry model# MID0704W
2 Suggested Answers
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Posted on May 27, 2010
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
When I turn on dragon touch model 10x I forgot my password .How can I access a screen to change it .
You cant. That's the whole purpose of a passcode. The only possible option is some tablets will, after a predetermined number of failed attempts to unlock, allow you to do a factory reset on it.
Jul 19, 2016 | Dragon Touch Tablets & eReaders
I have a dragon touch tablet model A93 and touch screen is not working. I can't tap or press anything
Can you turn it off? If so turn it off then hold the volume button down and the on button at the same time for about 10 seconds. Factory reset will be available to you then.
Hope this helps
John
Jun 13, 2015 | Dragon Touch Tablets & eReaders
I need free firmware and drivers for 7 inch dragon touch sentry chinese tablet
You can use the momo9 firmware. 4.0.4 works great.
http://www.virtual-productions.nl/default.asp?page=21
Firmware for the Visual Land Connect 7 Works good too.
Jan 22, 2013 | Tablets & eReaders
Cannot download app on my sentry Dragon Touch tablet
go into the settings go to "apps" and allow apps from untrusted sites and then turn your tablet off then back on and you will be able to download apps.
Dec 27, 2012 | Tablets & eReaders
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
