Question about RXE160 Equivalent NTE16013-ECG POLYMERIC FUSE
Equivalent oil to Freol UX300 on R407c - RXE160 Equivalent NTE16013-ECG POLYMERIC FUSE
HELLO, My name is Timothy and I got a motor repaired for the Hobart H 600 stand mixer and I need to ask one Question. What is the gear oil that this model takes as I lost some of the gear oil during...
Planetary takes six ounces 150 weight gear oil if completely drained (i.e. Exxon Spartan EP 150 or equivalent). Transmission uses one gallon 460 weight (yeah, 460 weight!) gear oil (Exxon Spartan EP 460 or equivalent).
Jan 25, 2011 | Hobart HL600 Legacy Stand Mixer
Oil sending unit is toast. What is the trick to changing it, besides having very small hands and can see around corners? 2003 gmv v8
Engine Oil Pressure Sensor / Switch Replacement Removal & Installation 4.3L Engine To Remove:
Oil pressure sensor removal/installation (4.3L engine shown) gm-04-43-572.gif
  1. Clean the area near the oil pressure sensor.
  2. Remove the distributor.
  3. Disconnect the electrical connector from the oil pressure sensor.
  4. Using J 41712 or equivalent, remove the oil pressure sensor from the fitting. NOTE: Note the orientation of the oil pressure sensor fitting before attempting to remove it. This is so it can be installed in the original position.
  5. Remove the oil pressure sensor fitting, if necessary.
To Install:
NOTE: If the fitting has been removed, clean and apply sealant to the threads before installing it.
  1. Install the fitting until snug, if it was removed.
    • Tighten the fitting to 11 lb ft (15 Nm). Continue to tighten the fitting until in the original position.
  2. Apply sealant to the threads of the sensor.
    • Install and tighten the sensor to 22 lb ft (30 Nm).
  3. Connect the electrical connector to the oil pressure sensor.
  4. Install the distributor.
  5. Check the engine oil level and adjust if necessary.
4.8L, 5.3L & 6.0L Engine To Remove:
  2. Disconnect the oil pressure sensor electrical connector. chevy_aval15_02-04_opsocket.gif
  3. Using J41712 sensor socket or equivalent, remove the oil pressure sensor.
To Install:
  1. Apply sealant GM P/N 12346004, (Canadian P/N 10953480), or equivalent, to the threads of the sensor.
  2. Using J41712 sensor socket or equivalent, install the oil pressure sensor.
    • Tighten the sensor to 15 ft. lbs. (20 Nm).
  3. Connect the oil pressure sensor electrical connector.
  4. Install the engine sight shield.
6.6L Diesel Engine To Remove:
  1. Raise and safely support the vehicle NOTE: Clean the area around the sensor. Do not allow debris to enter the engine
  2. Remove or disconnect the following:
    • Engine oil pressure sensor electrical connector
    • Engine oil pressure sensor using a suitable tool
To Install:
  1. Apply sealant to the threads of the oil pressure sensor
  2. Install or connect the following:
    • Engine oil pressure sensor and tighten the sensor
      1. Torque to: 22 ft. lbs. (30 Nm)
  3. Lower the vehicle
  4. If required, check and adjust the engine oil level
  5. Test drive the vehicle to confirm the repairs
8.1L Engine To Remove:
  1. Remove the engine appearance cover.
  2. Disconnect the electrical connector from the oil pressure sensor.
  3. to remove the sensor.
To Install:
  1. If installing the old sensor, apply sealant GM P/N 12346004 (Canadian P/N 10953480), or equivalent, to the threads of the sensor.
  2. Using J 41712 or equivalent, install the sensor.
    • Tighten the sensor to 22 lb ft (30 Nm).
  4. Install the engine appearance cover.
Sep 18, 2010 | 2003 GMC Sierra 1500
Hello! I need to charge my home A/C.The label right that need r407c freon type. Can i use r507 freon insteed of r407c? I am asking that because i already have a gase with r507 gas. Thank you very...
No.... they are totally different gases and if you mix them you are really in trouble.... only use the specified gas and NEVER mix gases!!
heatman101
Aug 27, 2010 | Whirlwind FH-778 Air Conditioner
Where is the oil pressure sending unit on a 2005 4X4 Suburban 1500 5.3 liter
Removal & Installation 4.8L, 5.3L & 6.0L Engine To Remove:
To Install:
  2. Using J41712 sensor socket or equivalent, install the oil pressure sensor. Tighten the sensor to 15 ft. lbs. (20 Nm).
  3. Use a special socket such as J 41712 to remove the sensor.
To Install:
  2. Using J 41712 or equivalent, install the sensor. Tighten the sensor to 22 lb ft (30 Nm).
Aug 05, 2010 | 2004 Chevrolet Suburban
How do I download photos from my LG UX300 phone to my computer?
Нужно программное обеспечение для МТ-6225
Jan 30, 2010 | Cell Phones
Instructions to change oil pressure switch GMC denali xl
4.8L, 5.3L, 6.0L & 6.2L Engines
  1. If necessary, remove the engine sight shield.
  3. Using J 41712 or equivalent, remove the oil pressure sensor.
    0996b43f802053c2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using J 41712 or equivalent, remove the oil pressure sensor
To install:
  1. Apply sealant to the threads of the oil pressure sensor.
  2. Using J 41712 or equivalent, install the oil pressure sensor.
    1. Tighten the oil pressure sensor to 26 ft. lbs. (35 Nm).
  4. If necessary, install the engine sight shield.
Jan 18, 2010 | 2004 Chevrolet Suburban
The oil sensor needs to be replaced where is it
  1. Remove the engine sight shield.
    0996b43f802053c4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using J 41712 or equivalent, remove the oil pressure sensor-8.1L engines
To install:
    1. Tighten the sensor to 22 ft. lbs. (30 Nm).
Nov 15, 2009 | 2001 Chevrolet Silverado 2500HD
Is R407c compatible with R134a
no absolutely not! Those kits are also more trouble than they are worth if anything at all is not right in the setup. Its worth going and having it done proper, and its not too pricey as long as you phone around enough.My shop in NB charges $10 per pound and a flat rate for labor depending on vehicle. You will burn out the AC in about a month on the wrong refrigerant, they have r34 in r407 as straight up r407 is no longer legal as pure.
Aug 16, 2009 | Beam Industries Sunbeam 1349705 Air...
How to add Freon R407C to a ductless air conditioning unit
If you are not trained to at least charge a unit U will in the end do more harm than good get the proper service. what makes U think U need freon could just be dirty? Tom
Jul 10, 2009 | Heating & Cooling
Match up Carrier equipment
carrier did sell some systems with R407c as a quick fix to gov regulations for about 2 yrs. R407c is a blend . and is treated like R410a except R407c pressures are more simular to R22. being that the pressures run the same the system should work with out changing any parts that being said if the evaporator has been used for R22 the oil residue wiil give you problems ifit is a new unit you would be ok.
Jan 08, 2009 | Carrier 38CKC042 Air Conditioner
RXE160 Equivalent NTE16013-ECG POLYMERIC FUSE Logo
418 people viewed this question
Top Nte Vehicle Parts & Accessories Experts
Eddie Dalton
Eddie Dalton
k24674
jasbo
jasbo
Are you a Nte Vehicle Part and Accessory Expert? Answer questions, earn points and help others
