Question about Brother MFC 240C All-In-One InkJet Printer
BROTHER MFC-250C UNABLE PRINT 70 - Brother MFC 240C All-In-One InkJet Printer
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
komguy
  • 2306 Answers
SOURCE: Printer says "Unable to print 70"
Usually that error means the encoder strip behind the carriage assembly is out of position or very dirty. Best to remove the top cover to correct, you might also find a scrap of paper either on the extreme right or left stopping the carriage from moving properly.
Posted on Sep 15, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Posted on Apr 30, 2010
What is error # 6 on a Brother mfc 250 c?
http://www.manualslib.com/manual/21751/Brother-Mfc-Mfc-250c.html?page=116
Jun 01, 2015 | Brother Office Equipment & Supplies
Brother MFC 260c driver
Go to the Brother Solutions Center to find your drivers. On the US site, I could not find the MFC 260C so I chose the MFC 250C. there are drivers for windows 8 and 8.1
Go back to the the top of the website, select the country/region, select the machine, and click download. Select OS. Download the whole software suite MFLPro compatible with your machine.
Brother MFC 250C Downloads United States
Jan 27, 2014 | Lenovo G500 59373039 Intel Core i5-3230M...
PRINT UNABLE 70
You would need to remove jammed paper opening back cover.
Nov 18, 2013 | Brother Mfc 250c Clr Inkjet P S C F Usb...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Need software for my printer (model # - MFC-250C and MFC-290C)to install in my computer.
Hi Peniueli!
You can download the MFC-290C software from here - http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc290c_all
and the MFC-250C from here - http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc250c_all
In both cases you need to select first your operating system (windows 7, vista, xp, etc) and that the language. After that you press on Search and then, in the opened web page, you press on Download and Information.
Hope that helps. Good luck!
Feb 27, 2011 | Office Equipment & Supplies
Hi, Im Randy from Philippines..!a have a brother printer mfc-250c..!how can i solve this?the printer said INIT UNABLE 64.
you need to reset your network storage because itmay be to full to take in anymore thankyou for using fixxya.com
Jan 21, 2011 | Computers & Internet
MFC-250C "clean unable 46", what
to clear the problem on a 250c turn the printer OFF
then turn the printer back on while holding the menu button down.
when the printer is on the FAX/SCAN/COPY/PHOTO buttons will flash
then press numbers 8 and 0
then keep pressing the up arrow untill you see PURGE and some numbers after it.
when this is on the screen press 2783
the numbers after purge will now change to all zero's
press ok the then 99 and you are done
Jan 14, 2011 | Office Equipment & Supplies
I have a year0-old Brother MFC-250C which worked very well -- even after I upgraded to Windows 7. But... when I replace ink cartridges, they don't print. I'm now down to blue and yellow...
yup,,, that is some problem with win.7,,, you try using this printer with win.xp,, it will work fine,,, your printer will miss printing line,, rest will work fine
Nov 22, 2010 | Brother MFC 240C All-In-One InkJet Printer
How to scan a document from MFC-250C printer
put the paper in to feed then press the scan button make sure you are connected to your computer or laptop so you will be able to print. also you have to have the software downloaded on you computer
Jul 12, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
118 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
