Question about Electrolux Dryers
My electro lux dryer heats but then shuts down with error code e64
Daniel S
  • 4323 Answers
SOURCE: I was drying and the
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Posted on Sep 13, 2010
ftw1952
  • 10319 Answers
SOURCE: My dryer get an error code "HP" and shuts off and
Here is a service maual for your dryer. Many reasons can bause this problem. If you can understand the technical isues for fault you can repair yours at a substantial savings
Good luck & here is the link to down load the manual
http://www.applianceaid.com/pdf/16022785.pdf
Posted on Dec 17, 2010
TheMobilian
  • 8220 Answers
SOURCE: affinity dryer shows e64 then
Error codes and more are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 20, 2011
SOURCE: error code on a Frigidaire affinity dryer E64
Heating element wire malfunction.
Posted on Dec 18, 2011
richroth
  • 9472 Answers
SOURCE: frigidaire affinity electric dryer says error E 64, what does that mean?
Heater has an open circuit and need to be replaced. Here is the part you need.
Posted on Oct 21, 2012
What is wrong with a code e64
It probably requires a technician to test it.
You haven't identified the manufacturer and model, but it is likely the following result of a Google.com search suggests a problem:
https://www.justanswer.com/appliance/7f3w8-frigidaire-dryer-e64-error-code-dryer-will.html
Why Am Getting Error Code E64 On My Frigidaire Dryer
Mar 19, 2018 | Dryers
Sumsung e64 error code
The e64 fault code commonly indicates defective dryer heating element or wiring to it.
Mar 05, 2018 | Dryers
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Jul 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
What is an e64 error code on electrolux dryer ewmed70jss?
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Electrolux Dryers
My frigidaire dryer is showing E 64 error code, what does that mean?
Hello florekedward - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing
Mar 05, 2013 | Frigidaire Electric Dryer
My frigidaire dryer is showing an e64 error code dryer works sometimes ?
The unit is displaying this code because the heater's circuit is open. A professional is needed to check the heater coils and connections for any open circuits. Replace the heater and/or wiring connected and then retest.
Dec 18, 2012 | Frigidaire Dryers
I was drying and the dryer shut off and gave an error message of E64
Hi
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
Dryers Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
