Question about Avanti WCR683DZD Stainless Steel Wine Cooler
Avanti wcr683dzd...its plugged in to a good outlet and shows no sign of power
Cord looks fine, its behind unit and never touched. I think it just shut off..we never shut it off and now nothing is working...no lights, no noise at all.
3 Suggested Answers
  • 159 Answers
SOURCE: 2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
Posted on May 16, 2009
SOURCE: AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Posted on Dec 16, 2009
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Why is it not blowing air
You said it doesn't blow air - but does it show any sign it is getting power such as a pilot light or LCD display? If not:
First, check the power outlet - is it live? Does the plug fit securely? No extension cord, right?
Second, plug the unit into another outlet - preferably the one where it worked before, if it's not too far away. Don't use an extension cord.
Third, let it sit for 24 hours. Sometimes moving a portable unit can require a waiting period before use.
Fourth, check all the access panels to make sure they are snug. Sometimes they have microswitches that shut off power when opened. Moving the unit could have dislodged one.
May 14, 2014 | Haier Commercial Cool 12,000 BTU...
Pioneer xv dv8
please follow this steps and fix it. God bless you
The power cord is disconnected or there is no power to the outlet. Check the cord and outlet. The protection circuit is activated. Unplug the power cord and plug it back in. There may be loose strands of wire touching the back of the receiver and triggering the protection circuit. Remove any excess wire from behind the receiver.
Oct 12, 2013 | Audio Players & Recorders
Window unit will not power on at all and throws the gfi on the power cord however a lamp pluged in the same out let works fine and the window unit works fine pluged in out in the shed and at the shop I...
If the window unit you are talking about is an air conditionner(sorry, it does not say it in the text), you must remember that an air conditionner needs far more amperage than a light or a freezer or both. Have you tried to plug the window unit alone directly into an outlet and not in a power cord? Let me know if these suggestions helped! Good luck.
May 08, 2013 | Refrigerators
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
No power, lights or anything
This is easy. It's the power supply problem. I bet you there is no juice coming out of the same electrical plug. So fix the plug or reset the circuit breaker.
Jul 31, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Mar 02, 2009 | Avanti Refrigerators
Avanti WCR683DZD Stainless Steel Wine Cooler Logo
Top Avanti Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
