Question about Compaq Computers & Internet
The screen has gone to reverse how do i get it back to positive
    Genius:
  • Compaq Master
  • 1,252 Answers
Press shift+ctrl+arrow key to change the direction
Posted on Nov 18, 2013
After having my vehicle jump started my screen has gone blank - the radio still works although you can't see what channel it's on and the screen works for the reversing camera - any advice?
Has the fuse on the back of stereo not sure if this is to do wig screen . Inside fuse box fuse should b ok because stereo comes on hope this helps
Jan 05, 2016 | Cars & Trucks
Panoramic roof problem - won't close all the way. Stops and reverses before completely closed
Your Limit Switch has gone bad or there is something in your track and needs to be cleaned
Jul 17, 2014 | 2006 Pontiac G6
Holden cruze wont turn on, stuck in reverse
manual lever position switch is bad or out of adjustment
Feb 24, 2014 | Holden Cars & Trucks
Automatic transmission will not engage gear
Sounds like the transmission is gone .Check the fluid level ,and sometimes the filters inside the transmission gets clogged up.have it checked by a qualified transmission mechanic.
Jan 05, 2014 | 2007 Chevrolet Chevrolet Equinox LT
Mower dies if you put in reverse while blades are engaged
These mowers are designed to do that, so that you don't accidentally back over a pet or kid while the blades are turning. My Bolens 38" has a key setting for reverse mowing, you have to trun the key to that position in order to bypass the safety swith for reverse.
May 30, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Reset phone by mistake sony ericcson, w2001, want the old data back, how to reverse it?
Sorry to say but for phone data, once its gone its gone. Theres no way to reverse it back. Its not like computer. The phone is using chipset memory data. Once u wipe it off by resetting it, the old ones will be gone.
Jan 17, 2010 | Sony Ericsson W200i Cellular Phone
Rear camera to show on screen in reverse? panasonic cq-vd7001u
It sounds like you may not have it wired correctly. When the vehicle is reverse the cam works, but when you shift to any other gear IE: park, drive etc you go to black screen as if no signal. I had basically the same problem on my unit, different unit but...on the back of my unit there was a wire, you probably have the same, that said rear cam 12v dc.I assumed this meant any positive wire would do, but this is NOT the case. That wire must be hooked to the 12v positive reverse light. With my cam I had the wires from the cam hooked up, red to positive reverse light wire, black to ground and obviously video wire to the video in on the unit. but the problem arose with that rear cam 12v dc wire on the back of the unit. It NEEDS to be connected to the same 12v dc wire as the cam itself. This acts as a 'switch' when in reverse, IE: the reverse lights come on sending power to the wires to turn on the cam. When you're not in reverse the camera 'switches off' because the lights are not on, thus no power is being sent to the wires, thus returning the unit to its normal operating screen. This worked for me, hope it helps. Good Luck.
Feb 18, 2009 | Panasonic CQ-VD7001U Car DVD Player
Samsung VP-D102D Camcorder
Remove the DV tape from the camcorder and check the position of the red tab on top of the tape. Reverse the position and see if it protection goes away.
Jan 17, 2009 | Samsung SC-D105 Mini DV Digital Camcorder
Upside down screen
well..that's really and truly dynamic..reversing the image field
go to control panel..system..device manager..
look for video adapters..uninstall it
at top, actions..scan for hardware changes
try it again
if that doesn't work, practice your yogic positions
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
