Question about Panasonic Televison & Video
Our panasonic plasms tv turns itself off after about 30 - 40 seconds
Our Panasonic 3d tv shuts itself down after about 30 - 40 seconds
    Top Expert:
  • Panasonic Master
  • 74,106 Answers
It sounds that the Y buffer board has the fault. Repair to plasma TVS is really a skilled work. For more information, check the link ttp://electronicshelponline.blogspot.com/
Posted on Nov 18, 2013
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 1779 Answers
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Posted on May 23, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
toolkits
  • 1099 Answers
SOURCE: my panasonic plasm tv wont turn on and the red
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.
Posted on Jun 02, 2010
Why does my panasonic tc p50st30 tv menu not work, tv will turn on but can not shut it off unless I unplug tv.
I would believe this to be a problem with the lvds cable that goes from your logic board to the main board. If your tv does not have a logic board, then it would have to be incorporated into the main board. A lot of times the connection gets loose on the main to logic board. If you reseat it, it may fix itself. If nothing else, you can pick up a logic board on ebay for around 25 dollars with shipping. It is usually very easy to replace. Most of the time, it's hidden behind the A board known as the Main board. It would probably take less than an hour to put in for someone not familar with the internals of a tv. Just MAKE SURE the tv is NOT plugged into the AC line.
Regards,
Joe Van Buren
Aug 06, 2014 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
My Panasonic TCP42GT25 turned off by itself and won't turn back on. The power source light is blinking 4 times and then pauses. any ideas on how to fix this? thanks.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 23, 2013 | Panasonic 42" Class Viera TC-P42GT25...
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
46 plasm tv
Likely a bad power supply in the set--only boards are sold so voltage into the supply and out needs to be the first thing that is checked.
May 04, 2012 | Panasonic Televison & Video
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
TV flickering when I turn a light bulb on in the same room
this is a sony feature, they have a sensor on the front of the tv to measure ambient and adjust the tv brightness to the ambient light.
if you want to turn this off?
call sony or put some black tape over the sensor.
R
Nov 30, 2008 | Sony PFM-42X1 Plasma TV
3d effect
Hello, please replace convergence output IC`s and R7048 (2,2R). If you need more info please contact me at LIVE Expert Assistance. Best regards, Arpi
Jul 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
