Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
My GE nautilus dishwasher does not drain all the water and sud, we opened and cleaned the dishwasher but the problem still exist. Our tenant told us that he used liquid dish cleaner instead of dishwasher powder and since then we have this problem, any suggestions. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
Stop using liquid-it's creating too much foam.
Posted on Nov 18, 2013
SOURCE: GE Nautilus dishwasher wont run
Thank you! Our dishwasher hasn't been working for so long. I've tried spinning the fan to get it unstuck a long time ago but I thought that wasn't the problem. The fan was stuck real tight and i couldn't turn it more than a quarter turn each time. This time it worked!
-Turned off power to dishwasher on circuit breaker
-Removed kick panel
-Used two screw drivers, one to turn the fan till I couldn't any more and the other one to hold the blades in place so that it wouldnt "unwind". Then I would turn the fan some more. It turned less and less each but after repeating about 5 times the fan got un-stuck.
-Turned the power back on to the dishwasher and turned the dishwasher back on and IT WORKS!
THANK YOU!!
Posted on Nov 09, 2008
  • 276 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
SOURCE: My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Posted on Apr 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: our GE Profile (Quiet Power 6) dishwasher is
The obstruction can be external to the unit. Check the drain at EACH connection working backward from the sink connection all the way to the motor pump outlet hole. Do not forget to dis-assemble the Air-Gap (if installed) and to check the inside of the garbage disposal hole also.
If all of these areas are free of obstructions then there is a good possibility that the pump impeller is either very worn / broken blade or there may be damage in the pump housing itself.
I think that if you look at the external drain lines, holes, and connections you notice a big change in the dishwashers performance.
Noting that you have hard water.... I really don't like promoting products.. but when one works and works well I will pass that information along.
There is a product out there made by FINISH called Jet-Dry and it comes in a mini basket form:
http://www.viewpoints.com/images/review/2009/134/13/1242326145-55717_full.jpg
or an additive if you have a rinse dispenser:
http://www.finishdishwashing.com/rinse-and-drying-agents.php
Lastly.... if you need to clean up the dishwasher.. on an empty no dishes cycle add 2 cups of white vinegar when you know the cycle has just started filling NOT draining and let it wash. Then do your dishes after that cycle.
Thanks for using FixYa.
Kelly
Posted on May 01, 2010
Testimonial: "very good advice. Covered the full spectrum of possibilities. Much better than the manual. thanks "
heatman101
  • 43501 Answers
SOURCE: GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
Suds won't drain out of bottom ??
There should not be suds in your dishwasher. If there is, it mean someone used dish soap instead of dishwasher detergent in the machine. To resolve this problem, get a package of Phyzeme (not correct spelling) stomach gas releif from the drug store, snip open about three of four capulets and squeeze the contents out into the dishwasher water after it has filled. Restart the dishwasher for 10 to 15 seconds and open door to see suds all knocked down. Close door and hit reset to allow pump out.
Mr Scott would say:
Oh, ya didn't go and tell them the truth now did ya laddie? How are they gonna think you're a miracle worker?
Jan 02, 2011 | GE Nautilus 24" Built-in Dishwasher
My dishwasher was pouring out suds onto our floor, why?
useing to much dw soap can cause it to fill it then drain it and again and again till its all gone
May 31, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Massive amount of suds coming out under the door.
Someone put the wrong detergent in this machine causing the suds problem. Manually fill the machine with COLD water. Set it to pump out. Refill with COLD water and pump out again. You may have to do this several times to clear the suds lock condition.
Use only COLD water as HOT water will cause more suds.
Aug 26, 2009 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Water does not drain from GE dishwasher.
Remove the drain hose from under the sink to verify that there is no clog. If the dishwasher runs in the "cleaning" cycle, but won't drain, you either have a clog or a bad solenoid. All the solenoid does is opens a little door to change from cleaning cycle to drain cycle. This part is VERY EASY to change. Definitely a project for DIY. The part runs around $60 from a parts place. Check ebay if you do not need it immediately and you can save abt $30.
Aug 16, 2009 | GE Nautilus 24" Built-in Dishwasher
I have a Maytag dishwasher that is just over a year old. I still have suds in the bottom when it is finished. What could be wrong?? I have tried liquid vs powder detergent. The dishes are clean and there...
You may want to cut back on the amount of detergent you are using. Your water may be softer than what the detergent manufacture has set there formula guide lines at. Scott
Apr 21, 2009 | GE Nautilus 24" Built-in Dishwasher
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
136 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
