Question about Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600 Overhead Cam
The spark plug is missing on my XR2600 Pressure washer. What NGK spark plug can be used to replace it?
4 Suggested Answers
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
SOURCE: xr2600 excell pressure washer I was using it and
I have the same problem and it seems the piston in the back has a ring and the ring is broken i half i'm talking it to get fixed tomorrow i will keep you informed.
Posted on Oct 11, 2010
  • 211 Answers
SOURCE: Using my new pressure washer, after on one tank
hi
try changing the sparkplug
regards savumihai71
Posted on Oct 30, 2010
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
My Mi-T-M 2600 pressure washer will not start, how do I clean the air filters and get a spark from the spark plug.
If you take out the plug check the tip for fouling - that will prevent it from firing properly. Testing for spark can be a pain -easier to just throw in a replacement plug and see what happens.
Did you remember to prime unit and set the choke on startup?
Try some starter fluid - if you get any sort of firing or miss you know you have spark.
Nov 10, 2015 | MI-T M Corp Chore Master 2600 P.s.i....
Xr2600 pressure washer does not start
hi
put a compression tester you will find low compression /
due to seized piston/piston rings/
Jan 02, 2018 | Garden
Replacement spark plugs
the plugs will be fine
the gap for electronic ignition can be up to .55"
how you pulled the rubber boots from the old plugs determines if you damaged the plug leads as the leads will not stand being pulled on
you may need new plugs leads
next misfiring , missing is seldom plugs but dirty injectors or low fuel pressure
a point here--- plugs fitted to efi or ECM controlled engines will under normal operating conditions outlast the engine as they are not subject to the high current of the older engines
Mar 24, 2017 | 1999 Toyota Sienna
I have a Honda XR2600 pressure washer. When the wand trigger is pulled, the throttle does not open, the RMD just drops. If i manually open the throttle, it works fine.
Your engine produces max horsepower at 3600 rpm. The engine throttle should be set to max before you pull trigger. Pressure washes generally do not have automatic throttle. You do not have to use max power, but enough power to keep the engine running when trigger is pulled. You washer will actually last longer if you only use about 75% of rated capacity. Good luck
Oct 15, 2011 | Karcher 2500 PSI Pressure Washer
Xr2600 excell pressure washer I was using it and it lost water pressure does not have any pressure. the engine runs fine just don't know what the problem is.
Aug 16, 2010 | Honda Garden
I changed the spark plugs on my 23006 nissan frontier and it started to baffle other works miss fire on different cylinders at different times. I think that I am encountering severy problems I just...
What brand of plugs did you use? Nissan engines are very picky, they only like NGK Spark Plugs, if you used a different brand than that your engine will run poorly and misfire.
Aug 15, 2010 | 2006 Nissan Frontier
What Spark Plug do I use for my Blue Max 2200 Power Washer.
Spark plugs: BPR6ES (NGK), W20EPR-U (DENSO). You cna cross ref any other equivalent with a spark plug cross ref book.
Thanks for choosing Fixya.
Kelly
Aug 12, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600 Overhead Cam Logo
266 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
