Question about Canon Ir-c5185i With Feed, Fax, Finisher, Bank - 664k Copies
Canon C5185i colors are messed up. They do not line up on each other.
I need to align teh colors so that it will print a picture. They are 1/4" off from each other
  • 624 Answers
SOURCE: Aligning Print Head Alignment
Try printing a diagnostic page without the PC, if it prints normal then the problem is on the PC, probably drivers or possibly the printer queue configuration. If it prints the same faded fashion then I would suspect defective or clogged inkjet nozzles. Warning, be very precise with the buttons you push, you are entering the printers diagnostic mode and you can cause problems if you push buttons out of sequence or if you push them too many times. - Start with the printer off. - Hold down the resume button and then hold down the power button - Release the resume button - Press the resume button twice, then release the power button. - Let green light blink while the printer enters the diagnostic mode. - When the printer is done press the function button once to enter the print diagnostic page mode, then the power button once to start the job. - When the page finishes press the power button once to exit the diagnostic mode. Let us know if you have any other questions and please don?t forget to rate the posting.
Posted on Jan 15, 2007
SOURCE: canon pixma mp145
try to make regular photo copies from the printer, if u still get lines then u need to replace the printer because its a hardware issue
Posted on Jun 12, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
VonZeppelen
  • 60 Answers
SOURCE: while printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Posted on Feb 22, 2009
komguy
  • 2306 Answers
SOURCE: Using a Canon pixma ip4000 and when printing
You need to replace the printhead, QY6-0049-000. They get plugged and cannot be cleaned. around $40.00
Posted on Jun 30, 2009
The color red, yellow and blue on my canon ir c5185i are not togeather. How do you adjust them to be one color?
Follow the instructions to align the colours try automatic align first, if no improvement select manual alignment.
Dec 05, 2013 | Canon Office Equipment & Supplies
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
On one side of the screen the red projection doesn't line up with the others. It is about 1" off at teh edge of the screen and lessens to where they align about 11"-12" towards the center of the screen. ...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis any alignment,have colors shadows or picture look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
While printing photos my printer has white vertical lines
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MP970 Streaks!
the colered pictures may be illegal to print like school pictures if you scan and then print them they will have a line threw them.
Sep 04, 2008 | Canon MP970 Photo All-In-One InkJet...
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Canon Ir-c5185i With Feed, Fax, Finisher, Bank - 664k Copies Logo
old marine
old marine
