Question about Garden
John deere troubleshooting
Tractor runs for a while then starts to sputter and quit
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Fuel starvation. Check no dirt in tank, check fuel filter, fuel lines, carburettor is clean, check vent in fuel tank cap.
Posted on May 08, 2014
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
Have john deere l130 that doesn't have spark
Sounds like the plug boot may not be on all the way. You may also have to check the spark plug gap.
May 04, 2014 | John Deere L100 Series
John Deere troubleshooting
Fuel starvation: Plugged filter or needle valve in the carb. The fuel is not getting to the carb fast enough to keep the float bowl filled.
Oct 30, 2013 | Garden
John Deere LX188 fuel mixture or choke problem
Try slackening the fuel filer cap to make sure there is not a vacum building up
May 30, 2013 | John Deere Garden
I paid for an answer and have not received one order # 318683 John Deere 110 tractor 1972. tractor started quitting under load but would start then run fine. Tractor quit while mowing and I found 2...
There should be a switch in the clutch pedal area. Usually safety starts for tractors is that your clutch needs to be depressed to start engine and you need to be seated to turn blades. Good Luck....
Aug 31, 2011 | John Deere Garden
My John Deere lawn tractor starts and runs ok but sputters and quit after usinng a short time and then is hard to restart. Putting gas directly into the carburator and it starts right away.
If you have a fuel solenoid switch on the float bowl you can remove it and replace it with a plug. You can leave the plug disconnected. Did it to mine and it runs better than ever. I think the solenoid get s hot and shuts off the fuel
Jul 31, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Have a John Deere L111 lawn tractor with running problems
I had the same problem and I figured out that it was the small hole on top of the gas cap. There is a vent hole on the top/middle and this got plugged with debris and caused a vacum in the gas tank which caused the engine to sputter and kill. Good luck!
Apr 12, 2010 | John Deere 1:16 Scale H Tractor with hay...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
