Question about Sony Cyber-Shot DSC-F717 Digital Camera
Camera won't shut down.Lost Pictures
While taking pictures camera went blusih on lcd screen.Won't turn off ..Pulled battery..I put battery baack in and I checked the Memory stick.. Lost about forty pictures
    Scholar:
  • 51 Answers
Your memory stcik might be starting to pickup a problem.
Farmat the stick as soon as possible for it will happen again. There is a bad memory alocation table or sector on the stick and formatting it might stop that sector from becoming completely useless, and rendering any access of that point as a sure way of losing more data.
Good luck.
Posted on Mar 09, 2008
SOURCE:
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Camera freezes
Does the camera work ok now? I suppose you should have offloaded the pictures before pulling the battery. What was the question?
Oct 08, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Sony Cybershot DSC-W180 won't turn on when plugged into computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 27, 2012 | Sony Cybershot DSC-W180 10.1MP Digital...
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Screen is black when i attempt to take pic
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to your camera. These replacement screens can usually be purchased directly from Canon or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras. Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny. Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding. Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.Replace the batteries. Turn the camera on and see if it is function.
Thank you !!
Jun 01, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen stays black
Purchase a replacement LCD screen, specific to a Samsung S860 camera. These replacement screens can usually be purchased directly from Samsung or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras.
Sep 02, 2009 | Samsung S860 Digital Camera
My camera is acting up
check the lens the lens might be closed if are open and hold for 5 seconds if it doesnt work take it to a specialist
Aug 07, 2009 | Olympus FE-170 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
