Question about Parmak Electrical Supplies
Digital read is 0.0 - Parmak Electrical Supplies
How to unlock a phillips flat panel tv
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Read more: http://wiki.answers.com/Q/How_do_you_unlock_a_Phillips_TV_using_the_on-screen_menu#ixzz1eP9NktX3
Nov 22, 2011 | Philips Televison & Video
2002 gmc abs light is on tested sensors with ohm meter right hand side tested 15 ohms and left side tested 0 ohms where is my problem.
all sensors will read different depending on the wheel. so hookup ohm test again and then spin the wheels the ohm range should vary from 0 to 50 ohms both side should match. the side that remains constant or at 0 is faulty.
Oct 02, 2009 | 2002 GMC Sierra
How do i change the name on the phone
This should be what your looking for..
From an individual extension with a Display Phone:
  1. Press [ Feature ] [ 0 ] [ 0 ]
  2. Press [ Left Intercom ] one time. The display reads: Enter Name (If a name was previously assigned to this extension, it displays instead.)
  3. Enter the two-digit code for each character you want to enter. (See Valid Entries below)
    For example, to enter the name Andy, press [ 2 ] [ 1 ] [ 6 ] [ 2 ] [ 3 ] [ 1 ] [ 9 ] [ 3 ] . The display reads: 12 ANDY
  4. If you make a mistake, you can press [ Mic ] to clear the display. Repeat Step 3 to enter the correct name.
  5. Press [ Feature ] [ 0 ] [ 0 ] to exit programming mode.
Valid Entires:
Letters A-Z, numbers 0-9, and blank spaces.
Character and Digit Codes:
Letters: Numbers:
A=21 N=62 0=00
B=22 O=63 1=10
C=23 P=71 2=20
D=31 Q=72 3=30
E=32 R=73 4=40
F=33 S=74 5=50
G=41 T=81 6=60
H=42 U=82 7=70
I=43 V=83 8=80
J=51 W=91 9=90
K=52 X=92 BLANK = 11
L=53 Y=93
M=61 Z=94
Mar 10, 2009 | Lucent PARTNER18 Corded Phone
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
One last question
you gonna need a multimeter set to OHMS , there should be a reading 2 digits up to 3 digits, if reading is 0 ,then element is damaged , hope this helps AJ
May 12, 2008 | GE GSH22SGRSS Side by Side Refrigerator
M853 Kodac Camera
go to kodak and chat with a customer care rep.
he/she will guide you as to how you can troubleshoot the problem
Apr 25, 2008 | Kodak EasyShare M853 Digital Camera
Reading multi zone DVD's
If you forget your 4-digit code
If you forget your password, to clear the current
password, follow the procedure below.
1. Display Setup menu then select an 1 level icon.
2. Use the Number buttons to enter the 6-digit
number “210499”.
3. Select [Yes] then press ENTER. The 4-digit
password is cleared. Enter a new code.
Mar 10, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Electrical Supplies Logo
Top Parmak Electrical Supplies Experts
 Kenneth
Kenneth
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
