Question about Pioneer VSX-816-K/S Receiver
Stand by button flashes but receiver wont turn on
I have a pioneer vsx-815 reciever and today while i was listening to some music like i always do, we had a power outage for a while and after the power returned my receiver wont turn on. the light in the standby button keeps flashing but it just wont turn on. if i push any of the buttons while the light flashes on. the light immediatly goes off for a few seconds. we have a had power outages before and it always seem to work like normal after the power comes back. i dont know whats different about today.
  • 4 more comments
  • MarkieB Nov 01, 2007
    I have the exact same issue just happened this past weekend. Really starting to tick me off.
  • coolrglenn68 Aug 30, 2008
    That is the same problem I have. The receiver quit working after a power failure.
  • Anonymous Mar 22, 2009
    the reciever heats up and powers off
  • Anonymous Mar 16, 2014
    it just clicks and after a few seconds goes into standby mode no lights on receiver come on
  • Jemuel Flores
    Jemuel Flores Jan 26, 2019
    Press and Hold
    Enter+Advanced Surr
    It works for my VSX-816 when it displays Amp Error
  • Jemuel Flores
    Press and Hold
    Enter+Advanced Surr
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Posted on Jan 12, 2008
Thanks so much for the help on Enter-Adv Surround - fixed my problem as well!!! I love the internet!
Posted on Jan 16, 2008
What do you do after you find the code like i have AMP ERR
Posted on Sep 28, 2008
2 Suggested Answers
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
On my Pioneer receiver (model # vsx-9100tx) MCACC light keeps flashing and system will not power on. Please advise.
Hi the mcacc light keep's flashing and will not come on. Can you help with this thank you Lee
Dec 22, 2010 | Pioneer Elite VSX-9100TX Receiver
The volume control button on the remote control does not work properly. Very hard to turn sound up or down. Have to push the button really hard. VSX-815-K
most used button on your controller could be a victim of grime carefully take apart the controller and gently clean the pickups with an eraser or light alcohol based cleaning solution a little goes along way also flip the button pad and inspect for dirt ok soft drinks are often the culprit hope this helps
Nov 17, 2010 | Pioneer VSX-815-K Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Pioneer VSX-815-K receiver with sub in standby
Have you looked in the manual?
No sound from subwoofer. • Make sure the subwoofer is switched on.
• If the subwoofer has a volume knob, make sure it’s turned up.
• The Dolby Digital or DTS source you are listening to may not have an LFE channel.
• Switch the subwoofer setting in Speaker Setting on page 40 to YES or PLUS.
• Switch the LFE Attenuator Setup on page 61 to LFEATT 0 or LFEATT 10.
May 13, 2010 | Pioneer VSX-815-K Receiver
Doesn't turn on
does it have the blue flashing light on the power button?
Oct 02, 2009 | Pioneer VSX-815-K Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Vsx-815 steady blinking blue light
Hold "Enter" and "Advnc. Surrnd" buttons on receiver at the same time.
Dec 29, 2006 | Pioneer VSX-815-K Receiver
Pioneer VSX-816-K/S Receiver Logo
2,277 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
