Question about Refrigerators
Bosch intelligent frost free 44
Necesita la plaqueta del preostato que maneja la temperatura. el modelo es"bosch intelligent frost free 40"
  • 87 Answers
SOURCE: How do I change the
reach behind the flap and pull on it .
Posted on Jul 12, 2008
TheMobilian
  • 8220 Answers
SOURCE: EL COMPARTIMIENTO DE ALIMENTOS NO ENFRIA
Claro del condensador. Motor del aceite. Dren claro.
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
SOURCE: necesito el diagrama del modelo CT-27S2S CHASIS:AEDP224
amigo te puedo dar fotos de la pcb, esque tengo uno con un problema de vertical y video y estoy igual que tu no tengo el manual si te sirve de algo mi correo es electroeljunquito@hotmail.com saludos
Posted on Apr 24, 2009
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Posted on May 12, 2009
Como programar control dish para que trabaje con tv magnavox
Carlos, mi nombre es Kimberly, y forma parte del departamento Social Media con DISH. Es un placer asistirle el dia de hoy. Para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si necesita asistencia adicional, sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 28, 2014 | DISH Network IR Remote Control
Necesito los codigos del control remoto dish ir remote 103602 para programar television jvc de 27 pulgadas
Juan Francisco! Mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Se que a este punto quizas mi ayuda ya no la necesite. Le proveere los pasos a como programar el control a su Tv por si en un futuro necesita la informacion. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor sientase libre de dejarme saber a kimberly.escobar@dish.com
May 10, 2013 | JVC Televison & Video
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Manual aerio 2003,maf sensor
El sensor MAF (Mass Air Flow sensor) esta dise?ado para medir el flujo de aire que ingresa al motor, este dato viaja hasta el PCM (Powertrain Control Module - Computador) por medio de un cable el cual env?a una se?al de voltaje que cambia de acuerdo al flujo.
En algunos sensores MAF la se?al entregada es una corriente pulsante de frecuencia variable (en modelos General Motors, por ejemplo).
El sensor MAF mayormente difundido es el el llamado Sensor MAF por hilo caliente. En este sensor, internamente funciona mediante un hilo muy fino met?lico el cual se encuentra a muy alta temperatura, en el momento que comienza a entrar aire el aire enfr?a este hilo y las cargas cambiantes de aire causan un efecto diferente sobre la temperatura del hilo, entonces todo el circuito que maneja el tema del calentamiento del hilo generara una se?al de voltaje de acuerdo a que tanto es enfriado.
Esto se encuentra incorporado dentro del sensor, el cual va ubicado en el sistema de admisi?n del veh?culo, lo m?s pr?ximo al filtro de aire del motor.
Internamente existe un circuito que permanente monitorea los cambios de temperatura del hilo por medio de un transductor el?ctrico, esto dentro del sensor.
Espero que esto le ayude. Su opini?n es importante y yo agradezco su tiempo y consideraci?n si se deja alg?n comentario testimonial sobre esta respuesta.
Gracias por usar FixYa, y que tenga un gran d?a.
Oct 26, 2011 | 2003 Suzuki Aerio
EL SENSOR DE BENCINA DEL PANEL SE QUEDA PEGADO LO LLENE Y SIGUE IGUAL CUAL SERA EL PROBLEMA. EL SENSOR DE TEMPERATURA AL INICIAR ESTA AL MAXIMO LUEGO BAJA Y ANDA PARA ARRIBA Y ABAJO DONDE SE ENCUENTRA ESE...
El sensor de nivel de combustible (bencina) se encuentra al interior del tanque de combustible
El sensor de temperatura del refrigerante del motor (ECT o Engine Coolant temperature sensor) se encuentra en el paso del l?quido refrigerador de la culata. El sensor ECT es una resistencia variable cuya resistencia cambia seg?n la temperatura del refrigerante del motor. Cuando la temperatura del refrigerante es baja, la resistencia del sensor es alta, cuando la temperatura del refrigerante es alta, la resistencia del sensor es baja. El m?dulo de control del motor (ECM) controles TEC tensi?n cincuenta veces por segundo y utiliza la informaci?n para ajustar el inyector de combustible de ancho de pulso y el tiempo de encendido. Cuando la temperatura detectada es muy fr?o, el ECM enriquece la mezcla de combustible.
Espero que esto le sea de ayuda.
Feb 06, 2011 | 1992 Hyundai Sonata
Cuando el coche esta frio, cuesta para encender, el motor tiembla y en la mayoria de los casos se apaga. porque es eso?
no dijo que motor tiene el carro, pueden ser varias cosas, necesita revisar:
El regulador de presion de gasolina, cuando lo prenda quite la manguerita de vacio y vea si sale un poco de gasolina, tambien puede tomar una manguerita conectela al regulador y suervale fuerte si le queda sabor a gasolina el regulador esta defectoso, remplacelo le ayudara ahorrar gasolina y trabajara mejor.
El sensor de la temperatura para la computadora le esta diciendo que el carro esta caliente y no le pone la suficiente gasolina por eso se apaga, no es muy caro remplacelo.
Algo que no me dice es si el carro trabaja bien despues de calentarse.
Revise esto, escriba para atras si necesita mas ayuda o tiene mas informacion.
Buena suerte
Jan 07, 2011 | 1994 Buick Century
Trobleshooting p0073 DIFINICION CIRCUITI ALTO DEL SENSOR DE TEMPERATURA DEL AIRE AMBIENTE AAT EXPLICACION El modulo de control electronico ecm a detectado una condicion de alto voltage en el circuito...
El código P0073 es descrito como el sensor de temperatura del aire ambiente del circuito de entrada de alto. Que consiste en el circuito del sensor de temperatura del aire exterior.
El sensor esta instalado frente al radiador, detrás de la rejilla. Probablemente el problema es que el sensor ha fallado o que el cableado presente algun corto en el mismo o cables deshilachados. Inspeccione los cables y conectores que lleva a la sonda. También puede hacer referencia a un manual de reparaciones de Jeep Liberty para obtener información específica, pero también se puede utilizar un multímetro digital (medidor digital ohmios voltios) para verificar la ohmios del sensor.
Espero que esto sea de ayuda (recuerde calificar esta respuesta). Buena suerte.
Nov 23, 2010 | 2004 Jeep Liberty
Falta controlador de red internett
HOLA! gusto en encontrar alguien en español!
Debes de buscar en la mother board el modelo de la misma, asi como ver, con lupa si es necesario, el número del circuito integrado que maneja la LAN, puede ser independiente o estar en un sólo circuito varios sistemas como LAN, AUDIO, MODEM y VIDEO juntos como en algunas mothers FOx... o en las PC100 venían esos sistemas dentro de una especia de BUS, la primera pantalla que presenta la máquina, dice hasta abajo el modelo de mother board, o físicamente en la parte impresa. Con el modelo de mother o de circuito de LAN podrás buscar el driver en google o en una página llamada driversguide punto com. Saludos desde Toluca, México.
Mar 10, 2010 | Intel D845GVSR Motherboard
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Nececito diagrama
tienes que dar mas informacion del tipo o marca del televisor pero si quieres intentar por ti mismo solo ve a la pagina de la compania que la fabrico y ve a soppporte manuales y diagramas ahi puedes encontrar lo que buscas es igual para todo tipo de aparato solo busca la pagina del fabricante
Nov 13, 2007 | Astar LTV2001 Television
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
