New external device is connected do you want to enjoy this do not have a external deivice how to i get rid of message
I had external hard drive got a new casing just want to know how to put in new casing
Hi
Which type or external drive you have (PATA) or (SATA), connect your driver to your External drive case, The external drive case have both of connector to connect the drive, chose your drive and connect the drive and connect the power, that ok
Now close your drive case and USB one side put in external drive case and second side put your Com/Lapi and switch on your external drive, your com/lapi detecting your external drive and your see the my computer external drive now what ever data you want to store, copy
and enjoy
May 25, 2011 | Computers & Internet
Western digital 250 external - not opening
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Nov 11, 2010 | Western Digital WD Passport 250GB Portable...
I have a 250 gb simpletech external hard drive. no. 96200-41001-077. I have used it as the time machine backup on my MacBook. It stopped backing up time machine recently. I got the message. Backup failed...
> icon does not show up on the desktop or finder
A major "clue" that one component of the external storage device has failed, namely:
* USB cable (try a different one)
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure
* optionally, the external power-supply that connects to the enclosure
Use a multi-meter to verify the voltage/amperage output of that power-supply.
(Not all external storage devices need such a power-supply.)
> can it be saved?
Partially. Disassemble the enclosure, and remove the disk-drive.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage-device. (Compare it to a heart-transplant -- same body, new heart.)
Nov 03, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Why do i have to reboot 4 or 5 times to get it to work?
This is probably done to the bios on start up you will need to load new bios when you get connected
May 09, 2010 | Acer Aspire One PC Notebook
How do I pair my iphone with bluetooth on my car
i have got a hands free set in my car and i would like ti connect it up with my iphone
Dec 01, 2009 | Apple iPhone Smartphone
Error message
this mean that the player didn't recognized any external device connected to it.Check the external device setting.
Jun 18, 2009 | Televison & Video
Pop up message says that I have a USB device that is not recogniz
Do you have anything like a printer or scanner or an external USB drive connected to the computer. If yes, then remove it. If not let me know.
May 14, 2009 | Toshiba Satellite 5005-S504 Notebook
Good Afternoon, I have an 64bit HP Pavillion System, brand new, with Vista Home Edition, I previously purchased a 1TB USB external HD Simpletech, works fine with XP, but not with vista, keeps looking for a...
there have been alot of problems in the past with vista not all external components are compatible with this program.i had the same problem with vista so i got rid of vista and started using windows xp home edition since then i have never had a problem with it not recognising any device i have added to my computer.i hope this helps.
May 06, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Hello , i have Windows Vista home premium edition installed in my HP laptop , i tried to connect USB external hard disk (containing Windows Server 20003 ) to my laptop USB port . means i want USB...
I do not believe that server 2003 is able to be ran from a USB device, I may be wrong, but I doubt it. To see what the error message is, you can be ready when it pops up and push your Pause/Break button on your keyboard, this should freeze the screen so you can see exactly what it says.
How did you install the server o/s to the external drive?
Dec 05, 2008 | Computers & Internet
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
