Question about Garmin Astro 220 GPS
DC30 collar.shows distance but a question mark instead of the dog logo..have done a re-set etc ,changed aerial but still have the same problem
Other collars work fine.have even tried it with a 320 and still the same problem
4 Suggested Answers
SOURCE: astro 220 and dc 30
after some thort i re aqainted my astro 220 and dc 30 again.
this was done at factory and i still dont no why it has done it in the first place, but i got it going again.
on the 220 you can add aditional collars so i went into add a new collar and followed the proccess
and it re astablished it self with the colar.
now i took it on a hunt with my dog yesterday and seemed to be working fine it was traking my dog like it was suppose to.
my dog took of and was been track then lost signal.
after some time i found my dog and noticed the dc 30 had lost its satilite link the red led lites were only blinking not double blinking like there ment to when they have a satililite link.
thort it mite have been out of range but got back into town and it still is not picking up satilite.
so can you please tell me why this is so.
ordered this unit all the way from america to australia and not haveing much luck or very impresed.
so anything you could tell me would be great. had this unit 3 days used it once.
reguards john guppy.
Posted on Nov 30, 2008
bbl242003
  • 1637 Answers
SOURCE: Garmin Astro 220 looses contact with dc30 collar
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Posted on Jan 22, 2011
  • 11800 Answers
SOURCE: we have 10 dc30 collars
You either have a bad contact to the antenna or the internal battery has started to fail.
The collar will have to be dismantled, the wiring checked and the battery tested to see how well it's holding the charge and replaced if necessary. Here is how
http://www8.garmin.com/manuals/DC30_DC30BatteryReplacementInstructions.pdf
Here is a new battery
http://stores.nextag.com/store/4857653/product/952529591/Garmin-DC30Bat-Lithium-Ion
Posted on Jul 11, 2011
How do I reset 2-minute delay?
[PDF]Astro® 320 with DC™ 50
static.garmincdn.com/pumac/Astro320_DC50_OM_EN.pdf
Page 2 ... Garmin®, the Garmin logo, Astro®, BlueChart®, City Navigator®, and TracBack® ... DC 50 Dog Collar Device. .... Changing the Length of the Dog's Track...... Resetting the Trip Computer. ..... the GPS antenna facing up, and the LEDs facing forward. 2 .... The 30-second and two-minutes rates reduce battery drain,.
Oct 19, 2015 | Garmin Astro 320/dc50 gps dog tracking...
My tt10 collar gets installed when i use add a dog but after that it will not comunicate with my handheld devise please advice i have changed batterys and antenna but still no luck
Please reference the manual...http://www.manualslib.com/products/Garmin-Tt-10-3084259.html
Dog ID may need to be changed.
Select Dog List.
Select a dog.
Select Show Info.
Select
> Change ID.
5
Select an available ID
Feb 12, 2015 | Pets - Others
Why would my DC 30 come up as a DC 40S?
units run the same firmware.
badged as different models for different features
Jun 04, 2014 | Garmin Dc30 Extra Dog Tracking Collar For...
I want to make my dog a festive collar for Christmas? What are some good ideas?
You could start with some red ribbon. Add some bells that will jingle and some LED Christmas lights.
Dec 31, 2012 | Dogs
My Garmin Astro 220 will not pick up collars dc30 or dc40 outside 50-100 yards. I have updated all to newest 4.0. still not working. Any advise I have tried everything!
Try this:
  1. Power your Astro 220 ON
  2. Press DOG button
  3. Press MENU button
  4. Select DOG LIST
  5. Select the name of your DC 30 from the list
  6. Select SHOW INFO
  7. Press MENU
  8. Select CHANGE COMM. SETTINGS
  9. Choose OK
  10. Change your update rate to 5, 10, or 30 seconds
  11. Choose OK
If your update rate was set to 0 seconds, changing it to 5, 10, or 30 seconds will now allow for your DC 30 to communicate consistently with your Astro 220.
Aside from that, most problems with transceiver range relate to background interference, antenna/transmitter damage, and battery life.
Nov 17, 2012 | GPS
Is there such a thing as handmade pet leashes?
I found some gorgeous hand crafted dog leashes on the etsy. Com website. http://www.etsy.com/shop/alaskaleash Seriously, once you see some of the beautiful stuff being created out there, it will be hard to go back to the boring black standard dog leashes. I'm totally hooked now.
Aug 29, 2012 | Pets - Others
How much do dog harnesses cost and where can I buy one for my dog?
This really depends on the size of your dog and the style of harness you want. The price range from small to large harnesses ranges from $6.99-$54.99. I suggest looking around to find the right harness for both your dog and your wallet!
http://www.petmountain.com/category/58/1/dog-harnesses.html
http://www.nextag.com/extra-large-dog-harness/compare-html
http://www.petsmart.com/family/index.jsp?categoryId=2767069
Jul 19, 2012 | Pets - Others
How do I properly size a collar for my dog?
One of the most important sizing tips is to leave enough space for two fingers to fit between the collar and your dogs' neck.
I own 15 garmin dc30 collars and when hunting they are spred out in no specific order over 3 astro 220 hand held units. I am having trouble receiving all of the collars. On one unit i may pick up for...
Hi, thanks for posting your Question..
At times you may experience Problems with a Garmin Astro DC30 Collar. I've heard And experienced reports of the following problems with Garmin DC 30 Collars
Before trying to do a Hard Reset for the Garmin Astro 220 DC30 Collar you should try and identify if it is the collar or the 220 Receiver. the easiest way you can do this is to check your Tracking System with another collar. If the second collar works fine then you can assume that you DC30 is not working as it should.
First i would Check all the basics, make sure the collar is charged.
I also would Delete and Re establish the Dog Collar in you system by going to the Dog List on the menu of the Astro 200, I would probably recommend Resetting the 220 receiver since it is much easier to reset that than the Collar.
Lastly, If these do not fix your problem you should try to "reset" the DC30 by
Removing the Back Plate (silver piece)
While Your looking at the connections for the two antennas, I would check to make sure there is nothing wrong with both the GPS antenna connection, and the VHF Antenna on the collar. Personally I carefully disconnect each and make sure they are both clean and free of Debris and Junk. (good Solid connection here will only help the performance of the collar) You can carefully use a brush or electronics contact cleaner for the VHF antenna (Screw mount) (See images below). I would not put anything into the SMP (square Antenna wire connector)
Removing the VHF Antenna on a DC30
Clean this before re-installing. Very Important to have a good Electrical connection3. Remove the Four Small Philips screws on the outside of the case to access the battery and electronics compartment. Very Carefully Disconnect the white battery connector from the board (see images below). Leave the battery Disconnected for about 15-20 minutes for a full reset, Reconnect it to the board.. (CAREFULLY) Here you Can see the battery Connector for the DC 30 Garmin
Different Angle of the connector for Dc30
As you re-assemble the Garmin DC30, Clean all seals and clean antenna connections.
Clean all seals and connections before re-assebling the Garmin DC30 collar
That is A Garmin DC30 Reset Instructions, and Many times when you are having Problems with Garmin DC30 collars this is the First step Garmin will ask you to do before sending them back.
Here is how to Mark a Location other than your location. For example You might want to mark the Tree before you get to it in case your dogs leave the tree. Most of the time If you are like myself You want to Scroll over and Hit the Mark Button, However that will just Mark Your current Location and not the location that your cursor is.
Here are the instructions To mark a location where your cursor is on your Astro 220.
Press map
Scroll the cursor over to the location you want to mark.
Press (ENTER) instead of pressing Mark.
If you press Mark it will mark your current location..
After you press enter.
It will either Select something that you've scrolled over and you should be able to save that as a Location, (Hint: you can change the name to what ever you want before you save it.)
Or if it doesn't select something it will say "no Map info at this point. Do You want to Mark a location here"
I know it's pretty confusing and counter intuitive, But that's how you can mark a location where you are not at.
If your Antenna's are not too OK,you can get a replacement from the below link:
http://garminastrodog.com/garmin-astro-dog-tracking-antenna-questions/
http://www.hdssupplies.com/garmin.html
Good luck and thanks for using fixya.
Jul 12, 2011 | Garmin Astro 220 GPS
I took my astro out for the first time and the handheld was showing the wrong direction and distance to my dog. Also the dc40 is blinking 3 times. Not sure what that means
I've had several Garmin Dog Tracking Collars and always had good luck calling the Garmin Tec Support people for guidance. Their support contact info can be found at the following site:
http://www.garmin.com/garmin/cms/home/support/supportcontact
Mar 14, 2011 | Garmin DC 40 GPS Dog Tracking Collar
Garmin Astro 220 GPS Logo
188 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
