Question about iLO LCT32HA36 Television
1 channel is showing. other channel is not changed by remote and tv key board.
My Speed con TV is showing FACTORY S1650S : 110113V3 code in screen and channels not changed by remote or tv key board but remote is working properly.
4 Suggested Answers
SOURCE: iLO LCD Color HDTV does not change channels / volumn...just turns on/off
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Johnny
Posted on Sep 27, 2008
SOURCE: My tv is stuck at one channel.
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
Posted on Nov 19, 2008
SOURCE: Cannot change channels
hi folks i have the exact same problem..
symptoms: remote or on board controls, volume, channel... nothing works but just the power on/off button..
problem: i have taken it to a repairman and after charging $80 initially he said, something digital is wrong nd that part had to be replaced, which happens to cost around $450-475, if he's not lying..
currently brand new 32'' TV's cost about $300-350 at walmart, where i boght this one from..
just shairng what i learned, and if someone has anything to say please go ahead. i would like to souble check my repirman but im dont wanna take it to someoneelse and pay another 80 to hear same story... good luck.
Posted on Jul 06, 2009
Why does my TV have no picture but still have sound? Its a LG LED Tv Model number 42LS3400-UA prod code 42LS3400-UA.APHLJD Serial number 2101NBSB2837 When turned on there is sound but no picture.
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
Feb 22, 2016 | LG 42LS3400 42" Class FuHD 1080p LED LCD...
Samsung flat screen UA22EH5000 tv playing changing station screen blank only light at the back of the screen
Probably the the T con Board is faulty. T con board is the one which drives the pixels. If its faulty then you will not get the picture. the light at the screen shows that its back light is ok. hope you
have sound too. And if you are able to change the channel then is shows that the main board is also ok. But it can on;y confirm by changing the tcon board.
www.electro-medical.blogspot.com
Sep 07, 2015 | Samsung Televison & Video
Vizio e472vle will not power on
Are you currently able to push the Device Selector Slider all the way to the right, into the TV position, and Press Power, to turn the TV On or Off? If not, go back to the first 2 or 3 Codes in your list (or the one the Installer selected, if he wrote it down) and see if you get AT LEAST that functionality out of the DTV Remote. One of the Codes will usually do that much, if you can get it to control volume, but not ALL of them: volume control, like many functions, may remain the same through several changes in Remotes, for many manufacturers. Don't forget to push the Slider back over to the standard DTV position, after you turn on the TV, or you'll change channels on the Vizio, and then you'll have to reselect DirecTV as your Input Source. :-)
As to finding the best possible Remote Code, for whatever reason, DTV's Online Remote Code Lookup Tool, and the Built-in Code Lookup often list Codes not found in the other. On top of that, If you call DTV Customer Service, after you've exhausted these other sources, and armed with your list of previously tried Codes and their results, in my experience, they often have 1 or 2 Codes I haven't come across, which will sometimes work.
I know this is kind of frustrating process, but hopefully it will be worth it. And being able to Power your TV via the Slide Selector is a decent fallback, even if you can't get it to work from the On/Off keys. I hope that helps.
Oct 18, 2013 | Vizio VO47L 47 in. LCD TV
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
Green screen when changing channels. Works find most of the time but on occasion when changing channels with the remote a solid green screen comes over the entire screen. You can still get sound, and you...
Hi Betty, I have the same problem and am researching it so far I have read a variety of solutions not sure what to believe however here are a few of them. 1.Conections on a little white ribbon strip/cable inside the tv needs to be cleaned 2.Change your HDMI cable to a better one and or use standard RCA jacks 3.Unplugging the tv for 10 minutes then plugging it back in. 4. T-Con or video board going out 5. Factory reset? I hope someone has a solution fo this.
May 12, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Factory on screen at startup then goesto Fac and remains there
open ur backcover go to the front bottom ur remote controls panel take it apart clean it.
take ur remote control apart too change batteries,a good cleaning
Aug 15, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
iLO LCT32HA36 Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
