Question about Samsung HT-HDP40 - 800 Watts 5 Disc HDMI Home Theater System System
HDMI conection hi guys I just bought a samsung HT-XQ100 home cenima, and i have a samsung lcd tv. i have a problem conecting with a HDMI cable it shows no signal on the tv can you help please?
  • buyayo03 Aug 16, 2008
    no picture using hdmi
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Posted on Jan 07, 2008
SOURCE:
Samsung PN43F4500AFXZA HDMI FIX
make sure you have it set to hdmi when cable is connected to source. try another working hdmi cable. try other hdmi ports.
May 08, 2017 | Samsung Televison & Video
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
Mar 05, 2010 | Samsung HT-XQ100 Theater System
Hi, I just bought a samsung blue-ray. I want hook
i can help with that have you looked on the back of the tv at all the jacks you have look at the color of the jacks some are red and white those are for audio and the yellow is video you need a pair of cables that will conect from you dvd to your samsung that same color on both ends their RCA cables or analog cables
Oct 29, 2009 | Onkyo HT-S780 System
Ps3 not conecting on 2 samsung tvs
Your ps3 could be in component mode. You will have to hook it back up on component mode, and go to the ps3 menu and change the setting to hdmi.
Aug 11, 2009 | JVC LT-37X776 37 in. LCD HDTV
No sound
If your TV is a Samzung, and has the Anynet+ function, you need to set the TV up with the Theater system. If there is an Anynet button on your TV remote, push that, and then select the function that sets up the sound system to the TV. If you don't see that button on your TV remote, then look for the option in the TV menu section. Once set up, you can use the menu under that Anynet button to turn off the sound system and return to normal TV audio... and while using the sound system audio, you can control the sound system volume, or mute it, with the TV remote.
Dec 22, 2008 | Samsung HT-Z310T Theater System
Advice on the best way to connect
If your system has hdmi in puts put the blu ray player into it then from hdmi out on system to hdmi in on your tv.Now take a phono lead from tv out put to a input on your system,could be marked "aux,tv,sat".For tv sound set the system to prologic2,blu rays should decode themselves,if not check settings for audio out on player.
hope this helps.
cable guy.
Jun 29, 2008 | Samsung Audio Players & Recorders
524 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
