Gmp125 4 on my unit the gas exhaust motor stays on and the out side unit do not turn on
    Master:
  • 571 Answers
Sounds like a limit switch is open.
Posted on Dec 20, 2013
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
I recently purchased a 20 gal/1.5 HP, model 921.166420. The reset button on the side of the motor, (thermal overload Protector?) cuts out repeatedly. The few times where the motor did run and the pr
Could be weak thermal cutout or actual problem with unit. Thermal cut out easy to check with amp meter. Connect meter as required to monitor draw as unit fills and make sure that it stays at or below usage stated. If amp draw stays below stated usage and thermal cuts out, replace the part. If amp draw goes over amount stated turn off compressor and listen for air leaks (usually check valve will leak back pressure to pump causing extra load on motor).
Nov 29, 2011 | Craftsman 150 PSI Air Compressor
Have a Goodman GPG13 single package gas-electric heating and cooling unit. Turned on the heat and the outside unit ran a short time then shut off. Smelled gas after it shut off. Is this an igniter...
There is a induced draft motor that will run first to purge the combustion chamber and induce a draft, a pressure switch closes proving an induced draft exists, thus allowing the spark and pilot gas, or hot surface ignitir and gas to pilot rsil and /or burners, a trial period for ignition about 30 seconds each for 3 attempts will be made and if not lit by the 3rd attempt it locks out, requiring a reset of power to unit to reset the module or circuit board etc. 1st see what motors running, is it the flue exhaust motor/induced draft??
Nov 02, 2010 | Goodman Heating & Cooling
Fault code says pressure switch lockout
This more often than not, indicates that your pressure switch is gone and needs to be replaced. Watch the YouTube video for a fuller explanation and heed the warning to use OEM parts! Gas Furnace Pressure Switch Failure and Replacement Amazon com gas furnace parts
Feb 06, 2010 | Heating & Cooling
How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Jun 09, 2009 | Heating & Cooling
Starts fine, but will not accelerate: Homelite UT-10798R
Do you have the H and L adjuster screws on the carb? If so, then normally I'd back out a little bit on the L (low speed side of carb) The instructions for adjusting carbs, years ago, on 2-stroke, say to back out on the L when motor will not rapidly rev up. Most 2-stroke carbs have these 2-jets. The L is for gas to pass to motor with butterfly throttle plate closed. When opening throttle plate, there is a sudden rush of air, at first, and this L adjustment is allowing enough gas to pass for motor to begin to rev. up. Then the gas will also flow through another small port H, usually a small brass tube in the venture area (smallest diameter section of carb). You adjust the H with the throttle wide open, motor revved up. Turn either in or out slightly till highest RPMS reached, motor smooth and fast, then turn H out about 1/4 turn. The idea is to run motor slightly rich for highest HP when under load (cutting). Hope this helps
Nov 18, 2008 | Garden
Gmh950904cxac burner on for a few sec.
sounds like a problem with the flame rod. small silver rod that sits by end burner and detects a flame.
Sep 11, 2008 | Goodman GMS90703BXA Heater
Whrilpool gas dryer
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD OF LAUNDRY. IF THE DRYER WORKS O.K. WITH THE EXHAUST DISCONNECTED, YOU HAVE A RESTRICTION IN THE EXHAUST DUCT SOMEWHERE.
Apr 22, 2008 | Dryers
Gallery gas dryer
one of 2 ways, diagram wasnt very helpful. the blower wheel either is threaded on the motor of is held on with a clamp. the clamp obviously undo and the motor will slide out, if its threaded look closely around fave of wheel you will see the words remove, with arrows if the direction to turn. Some are reversed thread. in which case you need to hold opposite side motor shaft with correct size wrench and unscrew from front( you wont have to completely remove the blower from housing it'll come forward enough to remove.the motor itself is held in by 2 plastic hold downs one in front and behind the motor.
Mar 15, 2008 | Frigidaire FGQ332ES Gas Dryer
No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Nov 08, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
