Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
T035 pto won't sync
Engine pto won't sync in with clutch, grinds in on low rtpm's
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
The power take off starts slipping and cuts off after it runs for a couple hours, what is the solutions to my problem
If you are talking about an electric PTO system, then there are two possible causes. The first is voltage drop. If your alternator is not charging the battery correctly, the available power to operate the PTO Clutch will drop below critical level. If you have to keep putting the battery on charge, this is almost certainly the cause.
The second possibility is mechanical failure of the PTO clutch. One of the most common clutch failures causes them to overheat and when the temperature increases, so does the electrical resistance.
Try this test:
Park the machine on a flat, level surface, switch the engine off,lock the brakes, remove the spark plug lead then remove the cutter belt from the engine pulley.
Now try to turn the PTO pulley on the engine. It should be firm to turn and you may hear/feel a slight grinding (this is normal). Next, turn the ignition switch to the 'run' position (NOT the start position), then turn the PTO switch to the ON position. Reach back under the machine and try to turn the PTO pulley again. This time, it should feel much heavier to turn because it's now connected to the engine shaft. It should turn smoothly for about 3/4 of a turn either way. Most importantly, you should no longer hear/feel any grinding. If you can still feel grinding, it means the PTO clutch has had a mechanical failure. In some cases, the fault can be rectified, however it is not generally recommended as a D.I.Y task.
Jun 02, 2015 | Garden
Pto grinds when engaging ford 1910
Feb 02, 2014 | Garden
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Apr 13, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
26 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
