Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
T035 pto won't sync - RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
Pto light stays on, tractor won't start (4400)
I would check the PTO switch with a meter, some switches uses 3 or 4 wires 1 or 2 is for the light and the other goes to the clutch. Part of the switch could be bad. Check the voltage on the connector before the switch.
Apr 03, 2012 | Garden
What's wrong when PTO won't engage? On my
should go from the switch to the safety switches to the clutch
Apr 01, 2012 | Briggs & Stratton Garden
Why won't my pto engage?
They are normally electro magnetic clutches, the click is the cluch engaging so i would guess it is working, arev you sure the belt is not broken or lose?
Feb 12, 2012 | Garden
T035 indiglo manual
top left button, to reveal alarm time, than the up button, which strangely is the bottom right button. very confusing.
Jan 03, 2012 | Audio Players & Recorders
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
