Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
Install the quick lock into the sprayer - Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
Just installed new Glacier Bay kitchen faucet with pull down sprayer; We have very little pressure. Is problem in sprayer or quick connector
If there is a way to remove the end of the sprayer, take it off and inspect for a loose piece of debris. They have a small port where the water flows and it may be clogged.
Apr 27, 2018 | Plumbing
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
I need a nozzle for the Ortho Dial N Spray Multi-use hose-end sprayer. I cannot get an answer back from Ortho on how I can get the part. How can I remedy this situation without buying another Dial N...
Sorry to hear about the problems you are having with your Ortho Dial N Spray. Please contact Ortho at 877-465-5160 and we will be happy to help you further.
Hilary @ Ortho
Aug 29, 2011 | Ortho Dial N Spray Hose End Sprayer
How do I fix a leak at the quick connect and the control body outlet tube?
I have the exact same problem. I just installed the unit yesterday and it does not leak until you use the sprayer. The sprayer leaks at the quick connect fitting at the base. As soon as I saw that new connection type I cringed. I may have to contact Pfister to see if they have any suggestions. I will be beyond ticked if I have to remove/reinstall a whole unit again.
Jan 02, 2010 | Price Pfister Marielle Kitchen Faucet with...
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
Sprayer Support
Measure the exact amount of material required for the job. Adjust the spray precisely - from coarse, drenching coverage to very fine mist to a long range pinpointed stream. Start and stop the spray quickly and at will. Prevent over-spraying by using the long-reaching hose and spray wand. Spray up or down as well as underneath leaves (where most insects and plant diseases can be found). Buy concentrated lawn and garden treatment materials, which in many cases is more cost-effective than the pre-mixed versions.
Aug 27, 2008 | Chapin Industrial 3 Gallon Viton...
Sprayer tips
Read and FOLLOW EXACTLY the spray material directions for mixing and use. Wear protective clothing including gloves and eye protection when spraying. Do not smoke, eat or drink when spraying; "wash up" afterwards. Spray on a calm day. Otherwise, winds may blow spray material off target. It's often best to spray in the early morning or late afternoon so excessive heat won't quickly evaporate the spray material. Follow the directions for use and maintenance that come with your applicator. Dispose of left over spray material and clean your applicator according to the directions on the spray material and with the applicator. Keep spray materials and applicator away from children and pets. Do not store spray materials in any but the original container in which they were purchased.
Aug 27, 2008 | Ultra Max R. L. Flomaster Atomist Electric...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
27 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
