Question about Broadcom 3Com 3C996 10/100/1000 Server NIC
3Com 3C996 10/100/1000 Server NIC xp 32
Driver xp
Have an HP pavilion a340n that I have restored, now can't get any network driver to work. Doesn't recognize the on board or any NIC card I try to install. The only card it reads I can not find a...
a340, circa 2003? wow, old...Goodwill has them way newer why use this old dog ?
why post lacking what OS this is?
xp dead
Vista dead
3com drivers, dead. about year 2000 dead, 17 years dead.
Windows 7 does not support many old chips.
nor does 10. (worse)
so?
if motivated to make NIC work
why not just buy a new NIC card from say newegg
or is this restore, a go back to windows 95,
back in the hey day of 3com, HP owns 3com now
but the those products all died back 17 long years ago
3com NICs 3C905 card, or the like?
I can run the PCI scanner on that PC
its a free program and get the
MFG code and device code. telling what chips both are.
nic and on board.
go here, find what matches your unstated os
buy it and it works.
PCI card, Rosewell.? $9 says comes with CD
says does all OS , see that?
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100158104%201100858365%20600016289%20600013857&IsNodeId=1&Description=nic%20card&bop=And&Order=PRICE&PageSize=36/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=nic+card&N=-1&isNodeId=1
ever use a PCI scanner to ID that on board chip
hell both .
http://pcdied.com/pci-101.html
if 9bucks is too much, only this scanner can tell you whats there in hardware.
the HP books are gone. long ago.
Jun 26, 2017 | HP Pavilion a340n (DQ099AABA) PC Desktop
Need driver for 3com Megahertz 3CXFE575BT XJack CardBus NIC
there you are
http://download.driverguide.com/driver/3cxfe575bt/3Com/d112287.html
May 02, 2011 | 3Com 3CXFE575BT / 10/100 CardBus PC Card...
I am using ProLiant ML110 Server i wont to use windows xp how to find the driver for xp
ProLiant ML 110 server series does not supports windows XP. It Support only the below OS.
  1. Windows 2000
  2. Windows 2003
  3. NetWare 5.1
  4. NetWare 6.0
  5. NetWare 6.5
  6. RHEL 2.1 (32 Bit)
  7. RHEL 4 (32 Bit)
  8. RHL 9
  9. SUSE Linux Enterprise Server 8
If you want to force this hardware to support windows XP, then download windows 2003 drivers which is equivalent to XP; but not the same as XP.
WINDOWS 2003 DRIVER LINK
Regards
Riztech
Nov 29, 2010 | HP ProLiant ML110 Server
R300 2nd NIC card "No driver installed"
I saw this a couple of months ago...let's see if I can remember:
In our case we even added a third nic (pci) and it wouldn't work
First, it is possible that the new mainboard has a different chipset on the nic than the last one. Check the driver d/l site for alternate drivers or Contact Dell support to be sure the right driver is in place.
Regardless of how secure your systems may be, please scan with the following three free excellent products:
malwarebytes antimalware
superantispyware
asquared free
Also, does the nic work if you slow it down or on auto?
I think it was malware in my clients' case. Get back to me if still ng and I'll ask their sysadmin if she remembers.
Aug 11, 2009 | Dell PowerEdge R300 Server
Nic driver
The driver for your card can be found here
Jul 02, 2008 | 3Com OfficeConnect 3CSOHO100B-TX Network...
Need windows 2000 server nic driver
Hello sir,
Try this link for Windows 2000 server.
http://www.opendrivers.com/driver/212753/3com-etherlink-server-nic-3c985-3c985b-driver-
windows-2000-free-download.html
Best of Luck
Don't forget to rate the solution.
thanks
Mar 11, 2008 | HP Compaq d220M (829160054797) PC Desktop
Clean XP Pro installed -- now NIC disappeared!
Well once you did a clean install over all of Dell drivers etc etc. You wiped out the restore artion that was on the computer. You have to go to Dells website and under the support tab look for the Nic card that you have inside the computer.
Feb 08, 2008 | Dell Latitude C610 Notebook
Computers & Internet Logo
13 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Laxman Bisht
Laxman Bisht
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
